tire deflating problem
Old Mar 24, 2008 | 07:31 PM
jordan 572's Avatar
Default tire deflating problem
we have a 2000 hummer h1 the front tires deflated from 25 psi to 10 during the 20 to the 24 this is the second time this has happened the first time i caught them at 8 psi the battery was also dead what is wrong
Old Mar 24, 2008 | 08:09 PM
Default RE: tire deflating problem
I don't think the two issues are related. In cold weather it is not uncommon to get significantly more air leakage from the CTIS system. Leak in the CTIS system could be at one of the valves or lines. 1-2 PSI per week is normal for many trucks. My 1997 wagon was doing what your is doing now and I had a bad valve and some cracked CTIS lines. Not that it gets cold here in SoCal but when it was cooler it leaked far more than when it was warm. If you have a battery that is older than 3-4 years it probably just needs to be replaced. If it is newer then the obvious answer is you have a draw from somewhere. Most likely culprits are aftermarket add ons like DVD players, radios, etc. If you can provide a little more information the members can help you more easily.
Old Mar 24, 2008 | 11:10 PM
Injunfarian's Avatar
check this:
http://www.hummerknowledgebase.com/tire/ctisleak.html
good diagnosis that has helped me
Old Mar 25, 2008 | 05:44 PM
h1sp's Avatar
http://flashoffroad.com/electrical/B...teryDrain.html
The more you read, the better off you will be.
Old Mar 25, 2008 | 09:19 PM
You can't know too much or have too many resources.
ingydrummer
Apr 12, 2013 09:59 AM
Hummin0814
Mar 18, 2013 12:12 PM
bigstick0000
Aug 29, 2011 10:04 PM
No more Jeeps
Apr 4, 2010 08:42 PM
