swing out spare tire rack problem
Old Aug 29, 2011 | 08:45 AM
bigstick0000's Avatar
Default swing out spare tire rack problem
i have an 03 h2 and my wife likes to drive it. The problem is when she goes to open the swing out and close it the tire carrier drops about an inch and she is not strong enough to close it. Is there a washer or something that can be done to raise the height of the carrier about an inch or so that will allow for closing the carrier without lifting the carrier up to latch it? thanks for your help
Old Aug 29, 2011 | 04:47 PM
Pauldy's Avatar
Maybe you can post a pict of your tire carrier? It really depends on what you have. I have the SMA tire carrier on my '03 H2 and it' is adjusted by like two bolts on the tow hooks. Just back them off a bit latch it grease the joint then tighten it. mine wasn't hitting the latch quite right and after doing that the pin requires very little effort now to push through.
Old Aug 29, 2011 | 09:09 PM
Muddydawg75's Avatar
I agree with him... since 03 didn't come with one from the factory there is a good chance you have an aftermarket one... you might need adjustment.... or you have lost a shim...
it's pretty good news... should be a minor fix.
I'm pretty sure there is no way that the factory ones can do that...
Old Aug 29, 2011 | 10:04 PM
ok, fixed it. The mounting plate kept shifting no matter how tight i cranked the bolts. I drillled throught the plate, added an additional bolt and it is cured. thanks again
hummerkidd
Jan 22, 2016 12:21 PM
tharber
Jun 19, 2015 07:21 AM
tharber
Aug 6, 2014 02:50 PM
petergriffen
Apr 10, 2010 10:51 AM
jstdoitt21
Mar 17, 2010 10:37 AM
