Thumping under floor board
Old Feb 23, 2017 | 09:55 AM
Synthetickiller's Avatar
Default Thumping under floor board
When driving, there's a very audible thump against the driver's floor board. I can feel it and hear it. If I roll the windows down, it's extremely loud. The noise starts up around 15mph and gets progressively worse through 30mph. Accelerating to 40-50 mph actually helps the severity thud, but it never goes away fully.
Any ideas?
Old Feb 23, 2017 | 11:10 AM
calif phil's Avatar
U joint going bad, exhaust heat shield loose?
Old Feb 23, 2017 | 11:38 AM
Good point about the U-joint. I'll check it.
If it comes to that, how long does the swap take, generally? I don't have as much time as I should to spend on it as I'd like.
Old Feb 23, 2017 | 05:30 PM
calif phil's Avatar
U joints are a pain. I would pull the driveshaft and take it to a driveline shop for replacement. That is provided you live in a town that has a driveline shop. If it is a bad ujoint go for the Spicer brand without a grease zerk. Those are the best.
Old Feb 24, 2017 | 11:43 AM
Thanks Phil.
I took the H2 out again today to for a really short trip. No symptoms of the thump under the floor board, but I am hearing a clicking that I heard before (should have mentioned that).
Perhaps that's the heat shield?
Old Feb 24, 2017 | 05:09 PM
Took it out again & now the break is acting funny...
It's missing the top mounting bolt on the driver's side. At least it's simple.
Is this the right bolt? (m16 x 2 x 41, 30 thread)
Dorman Brake Caliper Bolt/Guide Pin-Rear 14009 - Read Reviews on Dorman #14009
Old Feb 24, 2017 | 08:31 PM
madmayo's Avatar
That happened to me as well. Rear brake caliper though. Now I loctite them. And tighten them 2x tighter than my tightest turn. I have to use a Johnson bar to get them off.
acepanz
Mar 2, 2012 08:20 PM
TZHummer
Aug 7, 2011 07:01 PM
Fever4Speed
Apr 12, 2010 08:40 PM
rgvanover
Dec 29, 2009 06:03 PM
hsbertiii
Mar 20, 2007 07:05 PM
