tested PCM4less against JET
Old Nov 9, 2013 | 06:05 PM
  #21
HUMVEH2's Avatar
If it's surging, that means it running too lean under acceleration...
Old Nov 9, 2013 | 06:23 PM
  #22
byeatts's Avatar
YES, thats what i was telling them, they seemed to believe the timing was too aggressive and bouncing off the knock sensor, I build race motors for sleds and very fimilular with timing /fueling and I feel its too lean under acceleration also.I am doubtful this next tune will take care of the issue with the direction they are heading.
Old Nov 9, 2013 | 09:27 PM
  #23
skeeter's Avatar
Originally Posted by byeatts
The bottom line is PCM4less uses a generic tune for mail orders, it dosnt take account for the headers of different lengths .full exhaust cat Forward system which they acknowledge. my tune will require different specs than the mail order stock motor, they have never had my exact vehicle on a dyno and its best guess. they are altering my tune for another attempt. I run 35 Procomps /fuel wheels which are very heavy as well, ,All the options on the sheet for PCM tune are just eyewash , no they dont have a tune for different length headers/ high flow cat ect. as they would want you to believe, Vehicle surges with the tune and they are re- mapping the fuel at this time to try to address it,we shall see next week if it runs better than the jet chip which does not surge under acceleration.
I told them exactly what I was running, and they tuned it specifically for my mods. All the way down to the exact amount that the throttle body was ported.
Old Nov 9, 2013 | 09:39 PM
  #24
byeatts's Avatar
they take all the notes but seriously they have not dynoed an H3 with ported throttle bodies, or an H3 with full exhaust cat forward and high flow cat back with headers, It makes for a fancy form you fill out but pretty standard mail order settings, Case and point mine runs poorly and they have all my info.ported throttle body wont alter the fueling much.their form says list your header length. short ,med or long however the settings are the same for each, these are pretty generic with the few delete options for codes and trans shift points.you would need to take vehicle in and dyno for actual perfect tuning for your mods.its a shot in the dark, I have an engine dyno for the Mod powder sleds i build and every one is different in regards to optium tuning.
Old Nov 11, 2013 | 10:11 AM
  #25
telemike's Avatar
really best to have a local shop tune your H3 with HPTuners. They can adjust what PCMofNC has on there to better work with yours.
I was lucky to live close by and have them tune it for best performance for my H3. He mad a few adjustments on the test drive and reflashed updates.
Old Nov 13, 2013 | 03:10 AM
  #26
amrg's Avatar
The PCMofNC has an Hp tuners option, would that be better than the regular pcm flash?
Im going that route since Im overseas and the local guys just like to push everything to the max when tuning. Im worried that they'd destroy reliability/life expectancy of my truck
Old Nov 15, 2013 | 03:47 PM
  #27
byeatts's Avatar
Well PCM4 less has returned PCM and they would not listen to the fact that i,m lean under acceleration , just has HUMVEH2 as suggested. They instead thought it was bouncing off the knock sensor and pulled timing out, Its a total dog and un -drivable.way down in power from even stock.takes several second to rev up in neutral. . Back in the mail again, Again I am lean due to the headers, aftermarket cat back and the high flow cat forward system as well. There is very little restriction which allows to breath very well. needs more fuel under acceleration. They either need to listen to the what Magnaflow says [ It is lean]or return it to stock so i can run the Jet chip which ran strong,They have not done as asked and now another week without vehicle. . I do like the suggestions to have a tuner calibrate the PCM however I cant find any shop in C.A. that provides this service?
Old Nov 15, 2013 | 04:25 PM
  #28
HUMVEH2's Avatar
even if it was triggering the knock sensor due to having too much timing, richening the AFR in that area will also fix the problem.
You are better off getting it custom tuned using HP Tuners (as what telemike said), if you are make sure that PCM4less flashes your ECU back to Stock settings. Then when you take it to the shop for a custom tune, make sure to have them check first (before any power tuning). That your fuel trims on idle & cruising are as close as they can to 0% (anything between +3 & -3 are good).. From there they can do what ever the truck could take.
Where are you in California?
Old Nov 15, 2013 | 04:44 PM
  #29
byeatts's Avatar
I ,m at shaver Lake . above Fresno. I do appreciate you and Telemikes advice and believe your both spot on. A generic tune is a crap shoot with different modifications . Just trying to find a shop who can do the custom tune seems difficult. thanks
Old Nov 15, 2013 | 05:33 PM
  #30
HUMVEH2's Avatar
Call HPTuners @ hptuners.com I'm sure they can direct you to a nearest tuner...
