Temp flux after waterpump change
Old Dec 16, 2012 | 04:27 PM
Cornercarver82's Avatar
Default Temp flux after waterpump change
Ok so this weekend I took a road trip. Half way there my waterpump had a catastrophic failure, the pump and belt were changed(luckily a shop was close) and the system was burped. Now when I'm cruising my temp is normal(between the 1/4-1/2 mark) but when I stop at a stop light it goes up to the 1/2 mark, when I take off it'll drop all the way down to the 1/4 then back up to normal when cruising again. Anyone got any idea's? I'm also considering doing an electric fan swap but dont know where to begin, I'm sure just tossing any fan on it wont help anything
Old Dec 16, 2012 | 06:35 PM
Xlr8n's Avatar
I'd double check to see that all of the air was evacuated from the cooling system. If this temp condition never happened before the pump failure, air in the system would be my first guess.
Old Dec 16, 2012 | 07:44 PM
egroegart's Avatar
Ours has never ran between the 1/4 and 1/2 mark. It is always between the 1/2 and 3/4 mark. Never had a problem and I've read that's where they run normally at.
Old Dec 17, 2012 | 07:58 AM
See mines always been between the 1/4 and 1/2 mark. And I was thinking there might be another air pocket but every time I've opened the cap it's full, any tricks on purging the air out?
Old Dec 17, 2012 | 03:23 PM
What are the chances that nothing was hurt internally, it got hot but I shut it down right away, and it hasnt been acting weird or anything?
Old Dec 17, 2012 | 06:46 PM
egroegart's Avatar
How hot did it get?
Old Dec 18, 2012 | 08:19 PM
To the beginning of the red, then it was shut down, seems fine it completed the 700mile trip without fault after the new pump and belt
Old Dec 19, 2012 | 08:52 AM
2wheelmonster's Avatar
sounds like air trapped in the flow
Old Dec 19, 2012 | 09:34 AM
Get or borrow a Scan Gauge II or similar OBD II reader so you can see what the actual temp IS while it is doing what you described. The stock temp gauge is basically an idiot light with a needle, it is basically telling you the temp is changing, but you have no idea how much.
15-18 degree F temp swings are no big deal depending on weather conditions.
Old Dec 19, 2012 | 05:13 PM
It's chilly here and I'd say its a 10-15 degree flux
bad70ss454
Dec 20, 2021 01:47 PM
egroegart
23
Feb 7, 2015 10:34 PM
RGD
Nov 8, 2013 02:25 PM
StephenOSU
Sep 26, 2012 07:09 AM
Diablito
Feb 5, 2012 04:21 PM
