Tail Lights
Old Feb 6, 2010 | 07:48 AM
black nite's Avatar
Unhappy Tail Lights
2007 H3 brake and turn signals not working.
Put new bulbs in.
Still not working.
Any Ideas?
Old Feb 6, 2010 | 09:05 AM
drtom's Avatar
Banned
theres about 100 fuses
tom
Old Feb 6, 2010 | 09:17 AM
Recovery21's Avatar
Yes. I would start by checking the fuses. If they are all fine, get a test light and check the socket for power. If you have no power then check the connection at the socket on the back side of the housing. This connection might have came loose when you changed the bulb because those connections are strong but not indestructable. Or it could have easily came loose especially over the years of driving. Chances are the wires the rest of the way are fine. Try that! and see if that helps.
Old Feb 6, 2010 | 09:42 AM
Broken Halo's Avatar
Fuse #20 (rear turn signal lights, rear hazard lights)
Fuse #54 (brake lights)
'08 Birch White Alpha
Old Feb 6, 2010 | 11:54 AM
calif phil's Avatar
Turn on your emergency flashers and see if the rear lights up,that will do a bulb/socket check for you.
Old Feb 8, 2010 | 07:51 AM
black nite's Avatar
Checked all the fuses.Still nothing?
Old Oct 31, 2010 | 03:09 AM
Superleggera's Avatar
this exact same thing just happened to me... so what's the solution to this issue?
I have done a search and many people have had this issue, but there isn't really any real solution just yet... Please share your experience...
thanx in advance!
richie
Old Nov 1, 2010 | 04:48 AM
ok... problem solved... fuse 37 and fuse 43 were my problem and a faulty turn indicator.... probably went out when we were doing the nav system.
richie
LasseS
16
Oct 24, 2012 06:30 AM
BlackH3CA
Mar 7, 2007 09:56 PM
H8MYX
Dec 9, 2006 06:40 PM
HummBob
Oct 6, 2006 01:04 PM
HummerGuy
Sep 25, 2006 06:41 AM
