Tail Light Fuse
Old Apr 13, 2013 | 10:19 AM
GazKing's Avatar
Default Tail Light Fuse
Please could someone tell me which fuse box, and which fuse I need to change for the back tail lights. Brake lights work fine, as well as all the other lights. Its just my tail lights which have stopped working.
Maybe a diagram with a big fat arrow pointing to it. Just to make it really easy for me.
Cheers
Old Apr 13, 2013 | 01:52 PM
H2CANEPADESIGN's Avatar
Its in the owners manual, you can download the manual online if you don't have it.
Old Apr 13, 2013 | 03:15 PM
GazKing's Avatar
So, I've looked through the manual. I'm still pretty uncertain at which fuse is for the back lights? Any help anyone?
Old Apr 6, 2014 | 04:56 AM
smileynialley's Avatar
I'm sure you have found it by now but I think most of the fuses are located under the hood in the black box at the top right. Most of the fuses are labelled. If it's not in there it will be under the dash board, accessed by pulling the side panel off when you open the drivers side door.
Old Apr 6, 2014 | 07:04 PM
LoJac963's Avatar
A lot of the fuses are coded and without a manual you can't tell what does what. There is also a fuse panel with relays under the driver side dash by the brake pedal. There is also a huge relay on the back of the fuse panel which is in the side of the driver side dash.
flrtrader
Nov 29, 2017 01:19 PM
sullivanjm
May 11, 2010 10:39 PM
HUM2
Mar 7, 2007 04:33 PM
DWP99
Jul 28, 2006 11:18 PM
nascar 17
Mar 13, 2006 09:23 PM
