T-case question
Old Mar 14, 2013 | 10:21 PM
PSE30's Avatar
Default T-case question
I have an 08 h3 base. Is it possible to change the tcase 4low to 4:1 and if so how much am i looking at andhow difficult. Is it worth it even
Old Mar 14, 2013 | 10:59 PM
Very possible and has been done before.
$= depends on where you find one
It is a drop-in/bolt-on/plug-n-play swap.
Worth it? Depends on what you do with your HUMMER OffRoad.
Old Mar 15, 2013 | 07:57 AM
PSE30's Avatar
Well im not real hardcore off road but my buddys have some insane jeeps and trucks i dont wanna be the one getting pulled out all the time. Lol. How big of a job would you think a couple hrs work ya think. And where would i look junk yards off road shops?wats your suggestions on going about this i dont know alot about that area. Thanks
Old Mar 15, 2013 | 09:02 AM
happythree's Avatar
Default lower $ ratio
right now if you didnt know which one you had you couldnt tell the difference. both give a very low gear. rpm go up higher with 4:1 so you go slower and have more control but you wont notice and wont affect getting stuck/unstuck.
its another one of those things that is fun to talk about!
find a parking lot that has those cement park stops and practice slowly climbing over them,front and back.
if its important to you to be able to do that,like rock climbing, then go for the 4:1 , later go back and climb that park stop again and report back.
one thing you will notice is a much lighter wallet. and you'll have a spare transfer case!
Old Mar 15, 2013 | 09:15 AM
Look on ebay and Craig's list to start.
You have to ask yourself, what kind of off roading are you going to do? The lower range T Case is more for rock crawling than anything else. If your buds wheel in dirt, sand, or snow, the lower T Case won't make a significant difference. Tires would be much more important.
If you have mall crawler tires, forget about your T Case question, spend $$ in tires.
Old Mar 16, 2013 | 01:51 AM
Agreed DOC, If you haven't already invested in Tires, revocery and Protection that should be first on the list.
The 4:1 Tcase is a low gear "crawler" case. If muddin' is your thing a rear locker would be the best upgrade after the above stuff.
Old Mar 16, 2013 | 07:57 AM
PSE30's Avatar
Sounds good looking into tires for the last while now trying to find a good used set dont have a ton of money. Now wat do i need for recovery and protection and wats a good price range for a rear locker and is it hard to install
Old Mar 16, 2013 | 04:20 PM
UCP (under carriage protection) should be first on your list of protection items. Can't drive home with a smashed oil pan or tcase. Then some rock rails if you see rocks, stumps, berms, etc.
Recovery: yank strap and some shackles.
Locker: I would have someone who regularly does gear work do the locker. Electronic lockers don't require a compressor like the ARB lockers.
Old Mar 17, 2013 | 08:57 AM
PSE30's Avatar
Sweet thanxs guys guess while im lookin for tires ill start fabing some protection up ive also gone threw about 170 other posts and noticed some pretty good fab designs people have done such as the front tow bar and the nfab style bumber bar think ill add that on aswell. You guys are great thanks for the help. Be talkn at ya. L8r
Followme4x4
Aug 2, 2013 11:57 PM
offshoretechman
Oct 19, 2012 02:57 PM
hummex
Feb 24, 2011 11:14 AM
Zipthelipp
Feb 12, 2011 11:05 PM
Jul 19, 2006 03:05 PM
