switches for optional lighting
Old Sep 20, 2011 | 12:36 AM
mikeyd's Avatar
Question switches for optional lighting
has anybody had any luck getting part #'s for the 2 switches that go in front of the shifter beside the rear wiper washer, i'm guessing thats for some light options that are availible
Old Sep 20, 2011 | 03:24 PM
nitrousvert's Avatar
I gave up and fitted a couple of Autozone covered toggles. Quick and easy install.
Old Sep 20, 2011 | 04:46 PM
V8-H3's Avatar
Thumbs up
Looks pretty good too.
Old Sep 20, 2011 | 09:59 PM
rsc's Avatar
rsc
those look sweet! Looks like the perfect switch for the electric fan manual override, and maybe for some new lighting too!
Old Sep 20, 2011 | 10:17 PM
h3y's Avatar
h3y
Looks nice (carbon fiber look )
Old Sep 21, 2011 | 12:25 PM
mls100771's Avatar
Not to sound like a noob here, but why would you want to overide the electric fan?
Old Sep 21, 2011 | 12:27 PM
mls100771's Avatar
Nitrousvert,
How did you get around the integrated plastic clips at the back of the panel you mounted the switches to?
Was it Dremel time?
Mike
Old Sep 21, 2011 | 05:09 PM
Thanks guys. For 10 bucks each off the rack I’m pretty happy with them. One is for my Daylighters up front, the other is a manual switch to turn on the reverse lights. Always helps to have a little extra light out back.
As for the plastic clips holding in the button blanks, my first instinct was to reach for the Dremal too. But they can get away from you and scar things up from time to time. So for more control I used a utility knife blade held in a small pair of vise-grips. I heated the blade with a propane torch and used it as a hot knife. They came right off nice and clean with very little pressure on the blade.
A manual electric fan switch is used to operate the fan when the vehicle engine is shut off. This allows you to cool the fluid in the radiator without adding any additional heat. I have this setup in my Mustang to cool the system while waiting in the staging lanes between rounds. It can be a useful tool in many situations.
Old Sep 21, 2011 | 06:37 PM
rsc's Avatar
rsc
I would wire in an electric on/off override to the e-fan in case I'm out wheeling and need to turn the fan off. Like if I have to cross water or I get into a mud puddle that's deeper than I had originally thought and the water starts getting over the bumper I can shut the fan off and not have the fan slapping around in the water or burning up the motor or brushes/armature if submerged. Generally I stay away from the deep stuff but accidents can happen.
Old Sep 21, 2011 | 07:03 PM
DallaSStx's Avatar
I'm liking it... good job !
