SUNROOF WON'T CLOSE
Old Nov 30, 2007 | 11:27 PM
RUCKUS HUMMER's Avatar
Default SUNROOF WON'T CLOSE
So now to my problem. The other dayIhad the sunroof open and when I was closing it the thing made a loud POP!. I wasn't sure what it was soI opened it again and then tryed to shut it but it only went foreword about 3" and then got bound up and stopped. I could open it back up with no problem but it will notclose. I then opened it all the way up againand then Ipushed it foreword in the center of it and it closed ok. I think something in the track has broke and it is dragging on the drivers side. Help!
Old Dec 1, 2007 | 11:19 AM
Default RE: SUNROOF WON'T CLOSE
Sounds like a trip to the dealer. Sorry Brud.
Old Dec 2, 2007 | 03:55 PM
sbrennan007's Avatar
I had the same thing happen on my '05. Had to take it into the dealer. They ended up having to replace something in the track I believe. It may have become mis-aligned ever so slightly, enough to make it bind up and reverse. Nothing really that you can see either. They had to pull the headliner down to get to everything. It was a quick 1 day fix though.
Old Dec 6, 2007 | 10:37 PM
I found a brokenhalf of aplastic cap in the left side track. The track was also bent up on the rear slot that allows the sunroof to tilt up. I flatened out the bend a lubed the track but it still binds up on the left side. I can close it by pushing foreword on the left side so it squares everthing up. I cant see where the cap came from. does anyone know where it came from and can I get them without buying thecomplete sunroof?
Old Dec 7, 2007 | 08:46 AM
Sunroofs screw up if they are used a lot. The plastic clips that retain them in the track wear out and break. Without a pic of your piece of cap, I'm guessin that is what broke. Thoses clips are relatively cheap. The headliner needs to be dropped and once you go to all that trouble, you might as well replace all the clips......I know there is at least four, but might be up to 6-8??? CRS
You can get the clips from the dealer, take your broken piece with you, they might have to order them. If you are familiar with intereior work, you could do it, but it is not easy. [&o]
rprovo8
Jun 5, 2009 04:17 PM
frankenfish
Sep 14, 2007 11:13 AM
H34 pleasure
44
May 4, 2007 04:17 AM
khelms_98
Dec 25, 2006 04:38 PM
nascar 17
22
Jun 26, 2006 06:51 PM
