Sunroof leak (yes I read all of the articles)
Old Jun 25, 2015 | 04:44 PM
atari800's Avatar
Angry Sunroof leak (yes I read all of the articles)
I noticed that my front hand grips on drivers and passenger side are dripping water when it rains out.
I RTV'd the marker lights on roof
I RTV'd the weatehr stripping around the door when it seems to be a little easy to pull at the front top corner
I filled the sunroof reservoir to which I thought I found the problem as it was not draining.
I took some weed whacker cord and jammed it in about 4-5 feet and then the water drained away fast
Now a good thunderstorm hit, I go running out to my H2 and jump in. Same problem
Am I missing something? Is there another weak spot that I need to take care of?
*I guess I need to recheck the reservoir draining speed again but....
Old Jun 25, 2015 | 05:03 PM
atari800's Avatar
OK, rain calmed down and I jumped back in. Handles still dripping. I opened sunroof and the reservoir is damp and empty.
Old Jun 26, 2015 | 09:12 AM
atari800's Avatar
Ok so this morning I continue my "sealing adventure"
I decided to take some RTV and put some more around the marker lights
Also to note: When I took off marker lights and looked down in the hole, I could see the headliner but it didnt look stained.
Also to note: I inspected the sunroof track (U channel) and I do see 1 hole on each side that show the head liner too. But the reservoir would have to be backed up and over flow in there.
Maybe there is a read reservoir and the rear tubes are clogged and during the rain it floods the U channel and leaks in?
*However my truck is parked on a level ground
Any thoughts/clues/suggestions/spells would be greatly appreciated
Old Jun 26, 2015 | 02:46 PM
atari800's Avatar
Today we had a light rain shower. Sure enough - dripping from both of the handles.
I can pretty much rule out the marker lights at this point. I mean they are RTV'd real good
Suspects are: Sunroof, U Channel in sunroof, windshield, roof rack tracks
Unless it is the sunroof seal - not the side where the sliding window is but the side(s) that favor the roof itself.
Old Jun 26, 2015 | 04:13 PM
yoymon's Avatar
when mine came in the handles like that it was the corner marker lights, did you put a bead around hole that rubber bung fits into that the wires for the light run through? just another idea, sealed mine dry as a bone, I cleaned the area with rubbing alchohol first also followed the track where water flows and drains and removed a ton of crud, if you have to put a hose on one light at a time and or sunroof separate and see which area leaks
Old Jun 26, 2015 | 04:28 PM
atari800's Avatar
I did... I removed all marker lights and corner lights - smeared RTV on bottom of lights and in the hole. Placed it back on, ran more RTV around the edged and on the screw in the back too. It holds a puddle of water if I place my hand in front of it
Old Jun 26, 2015 | 04:29 PM
atari800's Avatar
Its the light rain that is confusing me now
Old Jun 26, 2015 | 04:53 PM
yoymon's Avatar
well id wait for a dry day and do the hose test, one spot at a time till u find the leak at least you can eliminate one area at a time that way, stopping water is always a pain
Old Jun 27, 2015 | 09:10 AM
atari800's Avatar
ok - I ran the hose over the marker lights for 5 minutes. Which is way more of an amount than a light rain. Figure 4 gallons a minute - so 20 gallons,
Not a drip
Ran water down the roof rack tracks for about 5 minute - nothing
On the door seals too
I ran in on the sunroof then I looked at reservoir and it was holding water, AH HA...
I watched it and it slowly goes down
Now when I tested it I ran a cup of water in a bone dry tube. I am thinking I didnt pour enough in the tubes so it emptied the reservoir quick - like filling a tall thin glass of water
So I filled up reservoir up until it held water - took my weed whaker line and snaked it through until it hit something then I banged at it or chopped at it. I looked at front wheels and seen it dripping to is was draining . So I fired up my air compressor and connected the "rubber tip" option to it, jammed it in the sunroof holes (set it for 45 psi if that makes a diff) and blasted it in there.
Now when I fill up the reservoir, it drains like a toilet
Official test will be this afternoon and the rainstorm that hits us
Old Jun 28, 2015 | 10:01 AM
atari800's Avatar
Light rain for about 30 minutes - h2 is bone dry
I think problem is solved
I did order this so I can get to all areas in sunroof - may as well clean all tubes
Amazon.com : JCS 1/4inch MPT Straight Tilt Valve - Rubber Tip Blow Gun : Sports & Outdoors
