Suggested tire pressure
Old Oct 17, 2006 | 01:48 PM
HEATHERH2's Avatar
Default Suggested tire pressure
What do you all recommend for tire pressure front and back? i have gotten conflicting answers and want to hear it from real Hummer owners. Thanks
Old Oct 17, 2006 | 01:53 PM
shortbus's Avatar
Default RE: Suggested tire pressure
i run mine at 40 PSI. but i've got 37" tires, which are bigger than the stock tires. if you've got stock tires, i'd recommend 35 to 38. when you decide to go offroad, air them down to 18, this will definitely help with traction on any surface. just make sure to air them back up when you get back on pavement.
Old Oct 17, 2006 | 02:00 PM
Sugardaddy's Avatar
That was an issue that I had as well. I messed with quite a few and found that I prefer 37psi. I went all the way up to 45 but man did it bounce around. I'm alittle older, although not quite as old as the "D" man, but I prefer comfort.
Old Oct 17, 2006 | 02:28 PM
Dennis's Avatar
Watchit Buddy!
I keep 40 PSI in mine..and I perfer it firm[sm=smiley2.gif]
Seriously..It will give better tire wear and helps with the MPG too.
Old Oct 17, 2006 | 02:36 PM
HEATHERH2's Avatar
are these tire pressures with stock tires you are giving? Mine have stock tires for now?
Old Oct 17, 2006 | 02:43 PM
shortbus's Avatar
40 psi would be fine for your stock tires, but it will be a stiff ride (snicker). if they're the bfg all terrains, they're rated up to 50, so try a few different settings between 35 and 40 and see how you like the ride (another snicker). the higher pressure ranges will provide slightly better MPG, but probably not enough to notice, unless you're running them now at 30.
Old Oct 18, 2006 | 03:00 PM
Greenblade's Avatar
i never checked air pressure until the first time i aired down and it was 38 / 39, so i've always just aired back up to somewhere around 40. Seems fine. But its possible that my impression of ride quality is a little "relaxed", as cranking my torison bolts didn't make a change to the ride quality that bothered me at all ( i think i like it better).
Its getting cold now, and the tire pressure is probably dropping, but i wasn't planning on messing with it as i've never adjusted tire pressure for temp change (if that's even a concern).
Old Oct 19, 2006 | 11:31 AM
HEATHERH2's Avatar
Thanks SB! I have mine set at 35 psi and i think they look and feel low to me. I will try upping the psi some. Thanks for everyone's feedback.
Old Oct 19, 2006 | 02:15 PM
Dennis's Avatar
Good point about temps..Always check the pressuure after the car has sat a few hours especially in the summer.
03Hummer1984
Feb 17, 2013 07:42 PM
PaulB
Sep 16, 2010 07:24 AM
psych0
Sep 16, 2010 05:35 AM
PaulB
Sep 2, 2010 12:50 PM
JeepeaterH3
Jul 8, 2008 11:04 PM
