Suggested Maintenance
Old Sep 1, 2010 | 10:47 PM
PaulB's Avatar
Default Suggested Maintenance
I own an 05 H2 which I bought new. Other than the water pump going out, I've never had a problem. I change the oil religiously. But now I'm at 84,000 miles and don't want it to break down on me. So to you Hummer experts, what should I have my local mechanic replace? Plugs, wires, radiator flush, change trans fluid, etc.? Thanks
Old Sep 4, 2010 | 11:02 PM
PaulB's Avatar
Well, no responses. I guess if it ain't broke, don't fix it!!
Old Sep 5, 2010 | 04:18 AM
olfart's Avatar
You are really way overdue for fluid changes....trans, cooling system, transfer case, both differentials and brake fluid. Alot of owners change fluids at around 35,000. I had my 2004 H2 done at 50,000 and I do notice an improvement in performance... especially trans shifting.
________
Justin bieber fans
Old Sep 5, 2010 | 07:41 AM
2004H2's Avatar
I had 04H2 changed every 40,000 miles, all fluids were repleced and the surpintine (Drive belt,a/c) belts replaced......air filter i did.......
Replace the Syn. oil Mobil 1 every 7,000 miles more or less
My water pump also went out at 60,000 miles, had the Coral Hummer dealer ship do the work........
Thats all ive done to it, except tires........Great Truck..........
My wife has the 2006H3
just replaced the Battery yesterday.........No other workdone except Syn. Mobil 1 oil changes
Have a Great day.....................Rick
Old Sep 5, 2010 | 08:05 PM
PaulB's Avatar
Wow, all of those fluids?!?! I guess I'll get a price from both the dealer and a local auto shop I trust. I know they've changed other H2's fluids as I saw one in there last year having it done.
I've never heard of changing the brake fluid though.
Old Sep 5, 2010 | 08:07 PM
PaulB's Avatar
Yeah, I'm on the second battery and second set of tires too. PLus I installed a cold air intake last year.
Old Sep 12, 2010 | 08:30 PM
PaulB's Avatar
So I'm taking my H2 in Tuesday to the local shop for all of the fluid changes and changing the plugs. They have done this with other Hummers and they have a good reputation. I was given a price of about $800. The dealer quoted me $1200 for the 90,000 mile scheduled service.
But I've not heard of changing the brake fluid. Is this really needed? If so why? Thanks.
Old Sep 12, 2010 | 09:20 PM
olfart's Avatar
Because of moisture buildup in the fluid. Have a look here
http://www.aa1car.com/library/bfluid.htm
There is a test that the shop can run to check the amount of moisture in the fluid.
________
Big **** Natural
Old Sep 12, 2010 | 10:11 PM
PaulB's Avatar
Got it. I'll get it done.
Another respondant said to change the transmission fluid but don't flush it because it will get metal filings into the gears. Do I need to tell them to NOT flush it, just change it like I do the oil?
Old Sep 13, 2010 | 04:22 PM
gunsammo2's Avatar
If they flush the system make sure they drop the pan and change the screen. Tell them you don't want it half a$$ed. If they don't then more then likely you will have metal going through the whole system.
