Stuck on Defrost
Old Jan 11, 2012 | 03:04 PM
ddawg187's Avatar
Default Stuck on Defrost
My 2005 H2 decided that it wants to only blow air through the defrost vents. I push the button to change it, but it doesn't do a thing. It will change from hot to cold alright. Anyone have any suggestions?
Old Jan 23, 2012 | 08:02 AM
ohchiiit's Avatar
mine just started the same problem yesterday, if i can get any info i will pass it along!
Old Jan 23, 2012 | 10:48 AM
lcurle's Avatar
does it make a clicking sound when you press the button, could be a bad relay not allowing the HVAC system to transfer the block plate from defrost to front vents.
Old Jan 23, 2012 | 01:49 PM
ohchiiit's Avatar
no sounds what so ever when i push mine
Old Nov 22, 2017 | 05:46 PM
DrDan's Avatar
It's the actuator just above the gas pedal. It is absolutely no fun to get out. Only two screws but the top one is almost impossible to get to. Once you pull it off, it is at attached to a round looking plate with slots in it. If the plate is rotated (either by the actuator or by hand when you get the actuator out) it will direct the air to the front vents. If you rotate it clockwise, the defrost vents. If you take the plate out, or it falls out like it did mine when I took out the actuator, the levers will spring into position such that the air will flow out the front vents and not the defrost.
Hope this helps someone.
Old Nov 22, 2017 | 05:54 PM
DrDan's Avatar
I forgot to mention that if you do a little searching you might be able to fix it by recalibration if you recently had a dead battery or new battery. Search for "HVAC Actuator Recalibration Procedure for GM Trucks and SUV's" . Good Luck!
Old Nov 29, 2017 | 08:48 AM
Welcome to HF. Please refrain from digging up old azzed threads and note that ALL H2 questions belong in the H2 section. You have merely perpetuated old crap in the wrong section.
See this thread re: Necro-bumping https://www.hummerforums.com/forum/n...bumping-23220/
nickoliboz
Nov 29, 2017 08:49 AM
HumRluvR
May 31, 2016 07:53 AM
CARdiac
Dec 9, 2013 06:00 PM
Hooty-Hoo
Sep 2, 2011 11:26 PM
lukascrystal
Dec 27, 2008 04:21 PM
