Stock Radio went out????
Old Jan 23, 2019 | 12:32 PM
No idea about the parking sensors but there are adapters to retain full use of Onstar, steering wheel controls, as well as the factory Bose amp, and even the backup camera if you have a newer model with that. If you have an older model with the no longer functional analog Onstar you can repurpose the Onstar mic and GPS antennas for an aftermarket stereo versus having an aftermarket mic sticking out somewhere or an aftermarket GPS antenna (if you were to get a stereo with those features). Works perfect on my Kenwood (the one I bought has built in Garmin GPS but most people use their stupid phones for that nowadays). I have full use of the steering wheel controls, the built in mic in the headliner works for me to make calls through the Kenwood stereo bluetooth connection, and I'm using the stock Bose premium amp, stock Bose sub and speakers. My 2003 does not have any sort of parking sensors (or tire pressure sensors which I think the newer models also have).
Replacing the stock stereo with another stock one can also be tricky. It will depend on whether you have the base Bose system or the premium Bose system and you might have to have it unlocked/setup with a Tech 2. Depending on the specific model, I do have a stock one I might be willing to sell. Since I have a Tech 2 I should be able to clear my VIN from it and set it so that it will autoconfigure on the next vehicle it is connected to.
Old Jan 23, 2019 | 10:14 PM
H2Miami's Avatar
You should have a 08 . I dont think previous years have parking sensors
the onstar on mine (06) was useless so it was removed
I kept the wheel buttons easy with the adapter
also I removed all chimes and bells but not necessarily you need too
Old Jan 24, 2019 | 07:08 AM
jsbihn's Avatar
Thanks for the advice on the aftermarket, but for right now i need to concentrate my money elsewhere so I am trying to see what can be done to get this running again.
I swear the thing acts like it just has been turned off. Like if I just hit the power button it will turn right on but the power button isnt making any kind of click or whatever to feel like it would be pushing in a button.
Clock on the radio still works
Hit the CD button, and everything lights up and it displays on the screen....
just no radio... like I said.... like its off.
Any ideas before I pull the dash apart and see what might be wrong with the unit itself
Old Jan 24, 2019 | 01:27 PM
Only other thing I can think is maybe the Bose amp decided to go but I'd think the radio would still cut on. Then again, you have a newer one and I'm not even certain those have the same amp setup.
Old Jan 24, 2019 | 02:44 PM
jsbihn's Avatar
mixman? what newer one do i have?
my h2 is a stock 03
Old Jan 24, 2019 | 04:13 PM
Ah - H2Miami mentioned an 08 a few posts up. Yours is identical to mine then.... couple of ideas.
First try a search on Google for 2003 Silverado radio dead. Maybe even try 2004, 2005 or change the terms up a little. It will also depend on if your has the navigation radio or the standard one.
this is one I spotted for the standard style ones...
There are two different fuses in the under hood fuse block. Radio and the second one Radio Amp (for the Bose amp).
Anyways from what I just found poking around some is it sounds like the amp might be dead. The below is from a GM TSB doc. This will depend on exactly which stereo yours has though. RPO codes are in your glove box on a decal.
With UQ7 without Y91 RPO Codes
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
This information is in addition to the normal no audio diagnostics which includes checking for shorted speakers or speaker wires.
Recommendation/Instructions:
For complaints of no audio from vehicle equipped with a non-class 2 amplifier, perform the following checks to determine if it is a radio or an amp issue. Do these checks with vehicle running, radio on and amp plugged in.
Check for audio at the Rear Seat Audio controls through the head phones. If there is, then the radio is producing audio.
Check pin B3 (switched 12 volts) for 12 volts. This is a radio output that tells the amp to turn on. It should show 12 volts, if it does not, and then radio B3 pin output is not operating properly. This could be caused if the radio is not programmed correctly or a circuit concern.
Check pin B6 (amp mute) for 0 volts to 5 volt. If the voltage is between 0 and 1 volt this tells the amp to unmute and play. If it shows between 3 and 5 volts this tells the amp to mute and stop playing. This could be caused if the radio is not programmed correctly or a circuit concern.
If the above steps indicate that the system should be playing then check for power and grounds to the amplifier and if ok, replace the amplifier.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
LarryDT
Jan 1, 2019 02:28 PM
kav315
May 12, 2013 08:55 PM
kevin s
Mar 24, 2012 04:12 PM
morbius
Apr 6, 2008 10:30 PM
Gooch
Oct 2, 2007 03:37 PM
