No Power To Radio
Old Dec 31, 2018 | 10:05 PM
LarryDT's Avatar
Default No Power To Radio
I was checking to see which pin has power on the connector that comes to my radio in my H3 Hummer (2007). I found the power in the orange wire in the upper right pin, but unfortunately the wire i was using touched ground and sparked a little. Since then there is no longer any power on that pin. I thought that I just blew the fuse. However, I have checked fuse #13 and it is fine. Is there another fuse somewhere that could have blown? Do you have any other ideas of what the problem is?
Old Jan 1, 2019 | 02:28 PM
LarryDT's Avatar
Well, I figured it out and am a bit embarrassed. However, I thought I would share the solution in case someone else makes the same mistake. When I was looking at the fusebox, I didn't realize that the "bottom" of the box was toward the cab of the vehicle when looking at the fuse diagram. So, I was testing Fuse #48 (which I thought was Fuse #13)! So, when I realized that I was looking at the world upside down, I found Fuse 13 and it was blown. Simply replaced the fuse and all is well!
chevin
Sep 6, 2018 01:56 AM
JerseyJoe
Nov 8, 2015 05:39 PM
TylerCorrect
Sep 6, 2015 09:14 PM
Rusty_03
Sep 4, 2012 02:45 PM
kdec19
Mar 9, 2008 08:41 PM
