STOCK GOODYEAR TIRES FOR H3 BASIC
Old Jun 8, 2008 | 12:38 PM
meero's Avatar
Default STOCK GOODYEAR TIRES FOR H3 BASIC
hi all
i have a new h3 2008 basic, with 1500km only,,,i have the stock goodyear tires but i move my hands on the outer surface of the tires i feel its un even wavy..... is this normal(i hvnt been ofroad until now)..... is it normal???? or do i need to check with the dealership,,,is it under warranty????
thnks in advance for ur advice
mero
Old Jun 8, 2008 | 01:12 PM
Default RE: STOCK GOODYEAR TIRES FOR H3 BASIC
Some wave in the surface can be normal. Can you get a photo of it?
Old Jun 8, 2008 | 06:15 PM
veves's Avatar
check your tire pressure and thats normal.The center is higher than the edges.
Thats why is recommends 30psi to get the tire flat.
Old Jun 10, 2008 | 08:31 PM
joewcob3's Avatar
I've got the same wavyness on the outer tread on my front tires too. I keep my tire pressure at approx 33 - 34psi cold. Maybe I should lower the pressure to 30psi?? 30psi just seems awful low, and I cannot believe that is what the GM spec says inside the door.
Old Jun 11, 2008 | 11:28 AM
T REX's Avatar
If its a problem you will feel a slight vibration normllly at quitehigh speeds If there is no vibration I would not worry about it.
kav315
Aug 18, 2012 07:56 AM
smokemaster60
Sep 7, 2010 04:56 PM
ScottAnthony
Aug 31, 2010 08:45 PM
BMoney5327
Mar 24, 2008 05:33 PM
salil75
Feb 22, 2008 11:57 PM
