sticky shifter button
Old Nov 23, 2013 | 11:56 PM
tandersn's Avatar
Default sticky shifter button
'97 TD WAGON
it started out, occasionally the button on the shifter wouldn't "pop" back up when I shifted into park. If I wiggled it a bit, it would. (note the key won't come out until that button pops up). Then, wiggling wouldn't help, but I could "pull" the button up with my fingers. Then the button came off from being pulled and wiggled too much. I now use a pair of needle nose to pull it back up.
There appears to be a mechanical cable (like motorcycle throttle cable) connecting the two, I assume this cable is the problem? Corroded and sticky?
Just wanted to check and see if this is a common issue, with a perhaps easier fix than replacing the cable?
Tony
XxCC3xX
Oct 27, 2011 06:43 AM
Muddydawg75
32
May 4, 2008 01:09 PM
JL
Apr 14, 2008 01:46 PM
Herm
Feb 6, 2008 07:45 AM
HummerGuy
Aug 9, 2006 11:09 AM
