Steering Wheel off-Center fix ?
Old Jan 29, 2010 | 10:09 PM
VQ35DE's Avatar
Default Steering Wheel Off-Center Fix ?
I have a new 2009 H3 and live 4 hours away from my dealer. The steering wheel is turned several degrees counter-clockwise (from center) when going straight. Has anyone corrected this problem by loosening the bolt that connects the steering linkage to the rack and pinion shaft ? If so was it hard to do ?
Old Jan 29, 2010 | 11:33 PM
the0007's Avatar
im a nissan tech, but i do all my own work on my h3. my steering wheel was off a bit too after i put 35s on it. all i had to do was align the vehicle drive it and reset the steering wheel and readjust my toe. id suggest just taking it in to anyone in your area that can align your vehicle for you. maybe cost you you $100. small change right.
Old Jan 30, 2010 | 08:07 AM
Disnydad's Avatar
Mine was like that when new, dealer did an alignment.
Old Jan 30, 2010 | 06:04 PM
drtom's Avatar
Banned
Default new?
4 hours is a nice ride in a hummer,, let them do it
actually when i mess with alignment i find that a big pipe wrench is best for the lock nut and tie rod.
loosen both and turn each one THE EXACT # OF TURNS.try 2 turns on yours.
just snug up the nuts, drive a mile and decide , if done, put some arm on the lock nuts.
i changed the cross member, spindles on my 80 mustang and aligned it mysely it tracked and tires wore great.
i had to use those pipe wrenches on the rear arms on my probe gt. 12 years+ rust was hard to crack.
btw its good to have 2-3 foot pipe extensions on the wrenches when needed!!
oh the good old daze
tom
Old Jan 30, 2010 | 07:17 PM
2wheelmonster's Avatar
If you have a floor jack, the pipe off of that will give you enough leverage to get any job done.
Humanoid
Private 'Wanted' Classifieds
Mar 27, 2021 02:23 AM
SafariHummerH2
Jun 9, 2016 12:12 PM
Hmmm...er
Jun 18, 2015 10:43 AM
drtom
Dec 7, 2010 03:55 PM
CWS
Apr 25, 2008 05:55 PM
