steering damper what tools needed?
Old Sep 22, 2014 | 10:39 AM
H2Miami's Avatar
Default steering damper what tools needed?
I just order the steering damper( Bilstein 33-174525) , looks easy to replace but after reading a few reports of DIY pp having trouble removing the old one .
Even some reported replacing other parts that got damage
How hard should be . Any expecially tools needed
Old Sep 22, 2014 | 04:12 PM
citiboy's Avatar
I had a problem removing the old one. I used the ball joint separator fork like this
Amazon.com: OTC 6299 Separator Set - 5 Piece: Automotive Amazon.com: OTC 6299 Separator Set - 5 Piece: Automotive
. Also, spray it with PB Blaster penetrating fluids.
I also installed the Bilstein steering stabilizer.
Old Sep 22, 2014 | 05:49 PM
H2Miami's Avatar
HI Citiboy ... Im going to spray Pb day before and allow it to do the work then try to remove it . If not luck then will rent the tool in A.Z .. Hopefully mine isnt too bad . I heard horror stories about it
Old Sep 23, 2014 | 08:46 PM
H2Miami's Avatar
HI citiboy ... exactly as you did .. Pb blaster then the separator fork .. took 20 min to replace .Cant believe how flimsy is the OEM . Only issue was a loose screw of the front of the skid plate not tightening.
Forsche
Jun 24, 2010 07:06 PM
shilly
Oct 10, 2009 10:06 PM
kball
Nov 24, 2008 12:58 PM
3dgames
Apr 3, 2008 10:33 AM
3dgames
Jan 15, 2008 10:49 PM
