Starter wont stop after start?
Old Sep 28, 2010 | 09:59 PM
firehawk24's Avatar
Default Starter wont stop after start?
Doesn't happen all the time (usually when its cold) I turn the key, motor starts but the starter keeps spinning for a couple of seconds. I have 2003 H2 with remote start, alarm. Is it the alarm system? remote start? starter? etc... and it seems that it is getting more frequent.
Thanks for any input!
Old Sep 28, 2010 | 11:13 PM
DTS62284's Avatar
Sounds like the starter is bad, sometimes the gears stick and will not pull back in. That my guess, with out being there its hard to tell.
Old Sep 28, 2010 | 11:23 PM
firehawk24's Avatar
Yeah, Im thinking the Bendix is hanging.
Old Sep 29, 2010 | 07:32 PM
bosch's Avatar
you might try reshiming the starter , even after you install a new starter it can hang up unless its shimed correctly. mike
Old Sep 30, 2010 | 04:46 AM
twr's Avatar
twr
Hi are using the remote start when it happens or the key itself?
Old Sep 30, 2010 | 07:53 PM
firehawk24's Avatar
Im using the key.
Old Sep 30, 2010 | 09:05 PM
twr's Avatar
twr
Hi this is a TSB it maybe what is going on with your truck?
INFORMATION
Subject:
Starter Cranks After Key Is Released (Normal Condition)
Models:
2003-2008 Passenger Cars and Trucks (Including Saturn)
2003-2008 HUMMER H2, H3
2005-2008 Saab 9-7X
Attention: This bulletin ONLY applies to vehicles with PCM/ECM controlled starters.
Supercede:
This bulletin is being revised to update the models and model years. Please discard Corporate Bulletin Number 03-06-03-001C (Section 06 - Engine/Propulsion System).
Some customers may comment that the engine starter will continue to run after the key is released.
For the 2003 through 2008 model years, the Powertrain Control Module (PCM) or Engine Control Module (ECM) controls the starter relay based on input from the key switch. When the ignition switch is held in the start position for 0.4 seconds, the PCM/ECM start timer is activated. Once the start timer is activated, the PCM/ECM will continue to crank the starter until either the engine starts or a no start time limit is reached.
Occasionally, the fuel pump module will take one or two seconds to build fuel pressure. Often this will occur after the vehicle sits overnight. During some vehicle starts, the customer may release the ignition switch key before the engine actually starts. When this occurs, the engine will then continue to crank until the engine starts or the no start time limit is reached.
This is a normal condition and no repairs should be attempted for this condition.
H3ummer
Aug 21, 2023 09:51 AM
simota1
Nov 24, 2021 12:45 PM
SafariHummerH2
Sep 18, 2012 11:31 AM
jfoulker
Apr 10, 2011 10:12 PM
jfoulker
Apr 6, 2011 12:17 AM
