Speedo Adjustment with 37's
Old Mar 18, 2007 | 09:43 PM
07HummerH3's Avatar
Default Speedo Adjustment with 37's
Sorry if this is a silly question as I can already imagine the onslaught - can (if so, where) can I get the speedometer/odometer recalibrated if I have 37's put on? I'm currently running 35's
Old Mar 18, 2007 | 10:05 PM
littlehummerboy's Avatar
Default RE: Speedo Adjustment with 37's
Not a stupid question. Obviously, your dealer can do it, but not sure what they would charge. Keep in mind, that whatever they DO charge, if you deduct that from what PCMforless charges(as they can change the speedo as well) you might want to spend a little more to get the PCM upgrade. In other words, if your dealer charges $75 do reprogram speedo only for you, that means you could get pcmforless to do it as well, but only pay $125 extra for a custom PCM tuning as well. That's off their regular $199 price. If they have a special on, the difference would even be less.
Old Mar 18, 2007 | 10:28 PM
Gunner_45's Avatar
I'm just curious if there is a limit on tire diameter within the PCM's programming.
It seems like I've heard that 33 is the biggest GM would/could do.
Has PCMFLgot a way around this? They do 35's right?
Old Mar 19, 2007 | 02:48 AM
importkiller's Avatar
you can get the speedo calibration box, I believe super lift or skyjacker makes it. It wires between the tranny and the pcm and you adust it with a small set screw until your speed is true. There is also a switch on it that you can switch back to stock if needed. I have one on my dodge and it works great, before hooking it up my speedo would read 60 and I my gps said 82. install is very easy, especially for me...I supplied the beer and my friend installed it, was a total of a 4 beer install
Old Mar 19, 2007 | 06:06 AM
Crash's Avatar
This may sound like a silly question, but what lift kit are you planning on using so you canstuff 37's under your truck..??
Old Mar 19, 2007 | 09:59 AM
07HummerH3's Avatar
ORIGINAL: Crash
I'm a Dumb A$$ having a total Brain Fart; I have 33's and want to put on 35's
LittleHummerBoy - Great suggestion, I'll definitely go the PCM route. Thanks
Old Mar 19, 2007 | 10:13 AM
dilo2001gt's Avatar
If your going to put 37 on we need pics
Then your going to make me spend more money
humith2
Sep 25, 2007 02:54 AM
Billyboys
24
Apr 3, 2007 03:18 AM
Ghostrider
Feb 22, 2007 06:22 PM
chaja
Oct 18, 2006 03:02 AM
ZOO
16
Sep 4, 2006 02:00 AM
