Shifting Problem
Old Jan 3, 2011 | 08:28 AM
H2 Jay's Avatar
Default Shifting Problem
Wonder if anyone can help. My truck has developed an intermittent shifter problem where the "MIL" light comes on and then it gets stuck in 3rd gear.
Clear the fault code and it goes back to normal for a few days.
From memory the code was P0785.
Any help is appreciated.
Cheers
Jay
Old Jan 4, 2011 | 03:18 PM
H2FAR's Avatar
Mine did that when the ignition switch went bad. That 3rd gear thing is LIMP mode. After a month or so of on and off again the key started sticking in the ignition too. That is a pita. Cost for that repair is ~ $275.00
Hope that helps.
Old Mar 28, 2012 | 12:03 PM
nncanfarelli's Avatar
What is a pita? My '03 H2 started doing this last night. Stuck in 3rd gear, check engine light is on, key stuck in ignition, gauge cluster kicks on about 30 seconds to one minute after the truck is already running. Had diagnostics run and came up with codes P0740, P0753, P0758, P0785, and P1860. PLEASE HELP!!
Old Mar 28, 2012 | 12:33 PM
nlhummer's Avatar
pita is Pain In The ***
Old Mar 28, 2012 | 12:45 PM
HAHA Thanks for the clarification!
Old Mar 29, 2012 | 09:55 AM
H2FAR's Avatar
I would bet anything it is the ignition switch. That is the only item that has failed on my truck and it has done so twice. Once under warranty and again @ 25/K miles. Not terribly expensive($275 at dealer) but will drive you nutz for sure. Let me know if the fix works.
A PITA for sure...lol
Old Mar 29, 2012 | 04:46 PM
I went and bought an ignition switch at NAPA last night for $40. Walk out of the store, fire up the H2, and everything is working fine. It must be a short somewhere. I am going to hold on to the switch just in case, but this whole thing is driving me nuts! Thanks for the advice
Old Mar 30, 2012 | 04:48 AM
H2FAR's Avatar
I took mine to the dealer 3 times because I could never get it tp act up when I was there. It's intermittent ...... Trust me it's the switch.
Old Apr 1, 2012 | 12:13 AM
2wheelmonster's Avatar
oh boy!!!
zebblue
Dec 19, 2009 07:52 AM
dleotaud
Sep 14, 2009 06:15 PM
FreebornHummer
Mar 13, 2009 01:41 PM
ducati996
Apr 18, 2008 12:36 PM
HummerH2
Mar 13, 2008 12:04 PM
