Shaking at speeds lower than 40
Old Aug 20, 2017 | 09:31 PM
Ewmoore99's Avatar
Default Shaking at speeds lower than 40
So I accidently jumped the truck today... went to fast over some train tracks and didn't see a drop off. Pretty sure the rear end stayed on pavement but the front end deffinately saw some air. Came down a little hard but not too extreme. Not far down the road after I stopped laughing I noticed a shaking/ vibration coming from what seemed like the front end. Once I got up to speed (45+) it was gone, or at least not noticable. Happens whether I'm on the gas or not. Still goes in a straight when I let go of the wheel. Where should I start looking for the problem?
Old Aug 21, 2017 | 07:20 AM
Ordieh's Avatar
Under the seat!
Old Aug 21, 2017 | 07:29 AM
Bent wheel/s, wheel hub/s, bent tie rod/s, upper or lower ball joints, etc.
Get under it and start looking for damage.
Old Aug 21, 2017 | 06:40 PM
driveshaft
Old Aug 21, 2017 | 10:28 PM
Happy Hummer's Avatar
Bet ya had fun????
I'd start checking everything important in the front end.....
Old Aug 24, 2017 | 12:22 AM
Ewmoore99's Avatar
I checked everything out last night and the wheels look fine, tie rods are good and I see no obvious damage on CV Axle. What should I specifically be looking for on there?
It seems to be vibrating the most when I have my foot on the gas, when I coast it is faint to nonexistent. If it was a bent wheel or tie rod I would think it would be constant, but then again I'm still new to this. How much more can I look for before I have to take it in? Thanks Man!
Old Aug 24, 2017 | 08:24 AM
If all of the above check out then move on to the front diff (supports, cross member, half shafts, prop shaft, etc.)
Old Aug 31, 2017 | 08:41 AM
classic87's Avatar
Check your front shocks.. they will cause vibration if they are loose/damaged.
Bartacus
May 26, 2012 10:35 AM
ayojel
May 15, 2012 10:34 AM
Pauldy
May 4, 2012 02:15 PM
LooseMoose
Aug 27, 2010 10:29 PM
scblueh3
Mar 17, 2009 07:39 PM
