SERV 4WHL
Old Sep 26, 2007 | 10:53 AM
IHNEVELS's Avatar
Default SERV 4WHL
Had to engage 4 low last night and the serv 4whl came up on the display. only have have 6500 miles on unit. has anyone had this happen. It goes out when put back in 4 high. Any suggestions?
Old Sep 26, 2007 | 11:23 AM
Default RE: SERV 4WHL
You have an H3 correct? When you shifted to 4lo lock, did it appear to operate properly as best as you can tell? This may have to be scanned and looked at by your dealer, but if it were me I would switch to 4lo (on dirt) drive a short distance at under 25mph, and then see if this warining repeats itself. This is the message indicating you may have a problem with your transfer case control system. If you where wheeling you may have loosened the Tcase wiring plug/connection, or the switch may be bad. Crawl under and look for the wiring plug into the Tcase and give it a wiggle. Otherwise, hello dealer. [:'(]
Old Sep 26, 2007 | 12:23 PM
IHNEVELS's Avatar
thanks,
i'll give it a try.
sgt940
Feb 16, 2013 10:01 AM
screaminhd
Sep 30, 2010 09:29 PM
thunderwolf
Mar 24, 2009 06:30 PM
NoDakH3
Feb 13, 2009 09:08 PM
Ghostrider
May 6, 2008 03:12 PM
