Serpentine tensioner
Old Dec 10, 2018 | 03:10 PM
Cymru's Avatar
Default Serpentine tensioner
I am enjoying the smells and sounds of a slipping serpentine belt in the 2007 H3. Bought a new belt in Autozone and then ran into the problem of removing the pressure from the tensioner pulley to remove the old belt. As far as I can see, the center of the pulley has a round, not square hole. What gizmo is needed to move the pulley down?
Old Dec 10, 2018 | 07:47 PM
Happy Hummer's Avatar
This is the tool...
https://www.harborfreight.com/serpentine-belt-tool-kit-63689.html?cid=paid_google_pla_main_newproductsgen eral_63689&gclid=Cj0KCQiAurjgBRCqARIsAD09sg-xHFqinGgw0EN1GFFKDwbPN3Dgp4wr5oDgluuo49ikk42mucaxj yAaAsBLEALw_wcB
HF has em. There referenced as Serpentine belt tensioner tool.
Old Dec 10, 2018 | 09:18 PM
Cymru's Avatar
Many thanks HH. I shall be out at the crack of dawn to get me one.
Old Dec 11, 2018 | 06:37 AM
sycraft's Avatar
Id replace the tensioner too, good maintenance and if your belt is noisy now, may have a weak spring in it.
Old Dec 11, 2018 | 10:52 AM
Any long 1/2" breaker bar will work, the square hex is not in the center of the Tensioner Pully, it is in the body arm of the Tensioner itself.
Old Dec 11, 2018 | 11:48 AM
Cymru's Avatar
Thank you Docs. Now it all makes sense.
Old Dec 11, 2018 | 01:57 PM
wfturner's Avatar
I carry a spare breaker bar and replacement belt in my truck.
It is not that difficult to change when you're off road and no one is around
Old Dec 11, 2018 | 07:13 PM
2wheelmonster's Avatar
If your strong enough you can probably just push on it
Old Dec 12, 2018 | 11:35 AM
Cymru's Avatar
Went to AutoZone to buy the tensioner roller assembly and take advantage of their generous tool loaner plan. Everything went well until I got to the refitting the belt. With the long bar there wasn’t enough room to get sufficient pull. The small bar which works with the long one has a 1/2 inch nub and the hole is 3/8 inch. Went back in, bought an adapter and two minutes later was running the engine.
Life is good and many thanks to all for the advice. I must admit the last time I changed a belt was on a VW bug many years ago.
Old Dec 13, 2018 | 12:29 PM
650Hawk's Avatar
Not sure why anyone would need to "buy" (or borrow) a belt tensioner tool when you just need a ratchet or breaker bar, but whatever floats their boat!
