sagging
Old Sep 8, 2011 | 05:53 PM
driver's Avatar
Default sagging
im new on here I have a 2006 H2 sut i came out 1 morning and my rear was all the way down, there is no error messag on the display
i checked both sensors our hooked up, i jumped relay over and the compressors work they pressure is not getting to the bags, my light in the rear and on the dash that you push for 2 inches more is on, i think it is either a control moldule, bcm or the control valve. i was wondering if this is a common thing.
Old Sep 9, 2011 | 08:26 PM
Draketh's Avatar
Are you sure the bags are not just getting the air but have a leak? This is the most common problem with the H2 if I recall correctly.
Old Sep 9, 2011 | 09:18 PM
driver's Avatar
no when i jump relay it will pump until it blows out bleed off, i check the valve above and no presser, it has a solinoid that opens up so air can get to bags, buts its not opening, the pumps wont kick on unless i jump it and there is no error that shows up on the bcm ( warning ) and my rear end is completely down.
Old Sep 10, 2011 | 10:18 AM
Draketh's Avatar
Ok, sorry then, outside of the airbags leaking I don't know much about the H2's hopefully someone else can help you.
Old Sep 13, 2011 | 12:44 PM
This has been moved to the appropriate forum. Where it was posted (Hummer Forums Help & Suggestions Center) is for help with using the forums, and not regarding any vehicle issues.
Old Sep 15, 2011 | 07:28 PM
driver's Avatar
Thank you
Old Oct 2, 2011 | 04:06 PM
driver's Avatar
i went ahead and put strutmaster springs on it. i think i like them beter than the air ride so far
rockstarbass1
Jan 2, 2015 09:52 PM
Indy
Mar 7, 2011 08:33 AM
RedWood
Apr 30, 2009 01:50 PM
