Rubbing in the front, levelin the front, raise the front to avoid rubbing, etc.
Old Nov 17, 2011 | 02:54 PM
federicoiz's Avatar
Default Rubbing in the front, levelin the front, raise the front to avoid rubbing, etc.
I am really very confused. I would like to buy buy new tires for my H3 Luxury and I do not do a off-road a lot.
I know there are few options like 285/ 65 R16, 295/75 R16, 305/75 R16, 315/75 R16 or 285/65 R18.
What of those tires do not create problems that I mentioned in the object?
Old Nov 17, 2011 | 03:30 PM
SundownAudioNY's Avatar
Its 285/75R16 not 285/65R16 and 305/70R16 not 305/75R16. Rubbing usually presents itself after leveling. Most 33+ tires will rub the sway bar after leveling. The rubbing is mild and does not cause any issues and only happens at full lock. If you really don't want the rubbing you have a few options to consider. First don't level it and some 33-35x12.5's will fit with out rubbing. If you want to level it, run a 33x10.50 or 35x10.50. If you want to level it and run a 12.50, your only option is a wheel spacer but don't use a cheap slip on style spacer but a quality bolt on spacer that is both hub centric and wheel centric.
Old Nov 18, 2011 | 03:30 AM
federicoiz's Avatar
What's level it? 33-35x12.5 is 285/75R16? And 33x10.50 or 35x10.50 is 305 or 315?
Old Nov 18, 2011 | 06:10 AM
Bunger's Avatar
First for leveling (Torsion Lift) information, read this: https://www.hummerforums.com/forum/h...ics-how-11428/
I posted this tire sizing information before in an older post but some newer people might find it interesting:
Inch sizing does not convert directly to Metric sizing
33x12.50R16 would be closer to 305/70/16
The first number in metric sizing is the tire width in mm
265 = 10.43"
285 = 11.22"
305 = 12.10"
315 = 12.40"
The second number is the Aspect Ratio, expressed as a percentage of the width. This determines the outer diameter of a tire.
The last number is the Rim Diameter (in inches)
285/75/16 & 305/70/16 are both commonly refered to as 33" tires. Here are the actual numbers
285/75/16 = 285 x 75% = 213.75 x 2 (tire walls) /25.4 = 16.83" + 16" (rim) = 32.83" tire OD
305/70/16 = 305 x 70% = 213.50 x 2 (tire walls) /25.4 = 16.81" + 16" (rim) = 32.81" tire OD
Old Nov 18, 2011 | 09:42 AM
federicoiz's Avatar
great info. thanks
Old Nov 18, 2011 | 03:10 PM
Xlr8n's Avatar
Another option is the newer sized 285/70-16 (rather than a 285/75) which is wider footprint tire (11.5") but is still a 32" tire. Looks bigger and more aggressive but retains the off-the-line performance of the factory 265.
Nitto make this size in their new Trail Grappler line and Toyo makes it in their MT line. The Toyo is a "C" rated (6 ply) LT which will have a much better ride quality than the regular "E" rated truck tire (10 ply) which is the Nitto is offered in.
Old Nov 19, 2011 | 04:08 AM
federicoiz's Avatar
I am not sure if I can find the Nitto here in Italy. I will try to find out. Goodyear Dura Trac looks great to me and also the BFGoodrich All-Terrain T/A KO, the General Grabber and the Yokohama Geolandar A/T-S Probabily it will find be easier to buy the BFG or the Yoko.
JCsh2
Mar 17, 2013 07:08 PM
Broken Halo
Aug 26, 2010 03:47 PM
duckstu
21
Dec 12, 2007 11:11 PM
HumV
Nov 16, 2007 02:24 PM
finall
Jul 21, 2007 03:42 AM
