Rough running, poor idle, spark
Old Aug 30, 2014 | 04:14 PM
Astro5169's Avatar
Default Rough running, poor idle, spark
It just started acting up. The cel was blinking and it was running rough. I looked under the hood and it appears the second plug a spark is around it at idle. I am pretty sure this isn't good. Do I need change plus or wires or other?
Old Aug 30, 2014 | 07:05 PM
ak47dennis's Avatar
Wow! I would say its time for plugs & wires.
Old Aug 30, 2014 | 07:58 PM
Astro5169's Avatar
I got them. What is the proper fitament for the plugs? The wire was cut and it was evident of missing.
Old Aug 31, 2014 | 04:31 AM
Astro5169's Avatar
I installed the one wire to move it and sure enough it is fine. How do I reset the cel?
The tourq is 20 ft/lbs and the gap is .040
Old Sep 1, 2014 | 12:42 AM
Astro5169's Avatar
Be careful on the drivers side with the water temp unit. I broke my connector and had to replace both.
This was not an easy fix but it work 5 hour project.
Old Sep 2, 2014 | 06:55 AM
calif phil's Avatar
The CEL will go out if the problem gets fixed. You can disconnect the battery if you do not have access to a code reader.
Old Sep 2, 2014 | 06:37 PM
Signal25's Avatar
StephenOSU
Sep 26, 2012 07:09 AM
Diablito
Feb 5, 2012 04:21 PM
Llamafood
Jan 11, 2012 07:16 PM
ZX10R
Apr 27, 2007 10:46 PM
Gunner_45
18
Mar 10, 2007 03:42 PM
