Rough running, poor idle, spark
1 Attachment(s)
It just started acting up. The cel was blinking and it was running rough. I looked under the hood and it appears the second plug a spark is around it at idle. I am pretty sure this isn't good. Do I need change plus or wires or other?
Wow! I would say its time for plugs & wires.
I got them. What is the proper fitament for the plugs? The wire was cut and it was evident of missing.
I installed the one wire to move it and sure enough it is fine. How do I reset the cel?
The tourq is 20 ft/lbs and the gap is .040 |
Be careful on the drivers side with the water temp unit. I broke my connector and had to replace both.
This was not an easy fix but it work 5 hour project. |
The CEL will go out if the problem gets fixed. You can disconnect the battery if you do not have access to a code reader.
I have something similar to this. I can connect with my Nexus 7 and pull codes and clear them
Amazon.com: iSaddle Super Mini ELM327 V1.5 OBD2 OBD-II Bluetooth CAN-BUS Auto Diagnostic Tool for Windows XP, Vista, Win7, OSX and Android (Blue Color): Computers & Accessories
https://play.google.com/store/apps/d...l.torque&hl=enI know you fixed it, but for future reference/codes. |
