Roof mounted marker lights
Old Mar 15, 2009 | 06:41 PM
provenceman's Avatar
Default Roof mounted marker lights
Hi all:
I have an 08 H3 Alpha and am installing individual roof mounted marker lights on each corner
The rear lights were easy, just tapped into the left and right lamp wiring
However I need some advice on where to tap into the wiring for the front set of lights
Do I tap directly into the left and right parking lamps or can I go to the fuse panel
I tested the front parking light fuse but it appears to be always on
Any advice is most appreciated
As always thanks for your help
Regards
provenceman
Old Mar 15, 2009 | 08:00 PM
Zipthelipp's Avatar
Cant help with the wiring but I would love to see some pics of the finished product.
Old Mar 15, 2009 | 09:36 PM
Default roof mounted marker lights
Will do as soon as I figure out how to connect the front set
Thanks for the interest
provenceman
Old Mar 16, 2009 | 05:54 AM
bonzaiii's Avatar
I just tapped directly into the left and right parking lamps for all of mine. It's very simple that way.
Old Mar 16, 2009 | 08:50 AM
Great
Thanks very much
I had figured that this would be the easiest but wanted to see what others like yourself had done.
By the way I like what you have done to your rig.
Where did you get your corner marker lights
Regards
provenceman
Old Mar 16, 2009 | 08:01 PM
BrickWurX Mfg.'s Avatar
We purchased our roof marker lights from HUMMER of Cincinnati. They ran a closeout sale about six months back , we got them for 325. If you pull the plastic A pillars cover off the driver side, there should be a wiring harness with a cap in it for just this purpose. Ours was near the lower airbox prewired.
We love the look, but drilling into the sheet metal Kinda freaked us out a bit! Especially when drilling to deep means a hole in the headliner! We were to lazy to drop it down first!
Old Mar 16, 2009 | 08:09 PM
That was a good price.
Yeah that is something that I am not comfortable in doing, so I chose just the four corners instead
No problem drilling into the plastic A pillar that I do not mind doing
Will pull them and look for the wiring harness.
Thanks very much for the information
Regards
provenceman
Old Mar 16, 2009 | 10:05 PM
bonzaiii's Avatar
For the front lights, rather than buying the entire marker light set, I thought to save $ by just buying the components... I bought the left and right light pieces from here:
http://hummer.autowebaccessories.com...1309_13004.php
The only problem with the light pieces was I had thought they came with bulbs/wiring, but they just came with the plastic piece! And it was supposed to require some bulb assembly (which I assume would come with the marker light set, which I didn't order)... But that was an overall blessing in disguise for me I guess because I had really wanted to use LEDs instead of bulbs (don't have to change dead bulbs every now and then too)..
So what I had done was to buy LED lights from my local pepboys, drill out the back of the marker piece, put the LED light in and silicone like crazy to seal the gaps.
Attached Thumbnails Roof mounted marker lights-1.jpg   Roof mounted marker lights-2.jpg   Roof mounted marker lights-3.jpg
Old Mar 16, 2009 | 10:07 PM
bonzaiii's Avatar
The info above came from this thread
https://www.hummerforums.com/forum/s...+lights&page=2
Old Mar 16, 2009 | 10:09 PM
Clever way to go
I like the led as well
They claim to last a good long time
No filliment to burn out
I'll try the site and see what they have
Appreciate the information
Regards
provenceman
