roof leaks...
Old Jan 22, 2011 | 02:29 PM
skyymaster's Avatar
Default roof leaks...
I was wondering if anyone has had problems with the running lights allowing water to enter into the roof area when it rains. I have tried several things to solve this problem and am wondering what it does take to stop the leakage.
Old Jan 23, 2011 | 08:00 AM
Lakeside Restorations.com's Avatar
Usually cleaning the sunroof drains & lines as well as making sure that the clearance lamps are sealed properly. Usually the lamps get loose and the seal no longer seals, allowing water in.. Jamie
Old Jan 26, 2011 | 05:13 PM
luda81's Avatar
I had leaks that was caused by the roof lights but were is the sun roof drain holes??? I want to clean them even though i don't have any leaks.
Old Jan 27, 2011 | 07:13 AM
If yours is equipped with them They are in the sunroof track assembly and hidden behind the head liner and body pillars. I would make sure your track is clean and that you have no debris in there to possibly block or bind anything.
alexismya
Dec 24, 2011 07:35 PM
BoneChief13
Aug 7, 2011 07:09 PM
jolibee30
Aug 18, 2010 05:35 PM
nicos
Feb 24, 2008 09:07 AM
syphon
Jan 13, 2008 12:15 PM
