Rims and Tires
Old Aug 6, 2007 | 09:53 PM
whitemexican's Avatar
Default Rims and Tires
Hey guys I am looking into buying some new rims and tires for my H3 Hummer and I was looking at Tirerack.com and I pick a set of rims I wanted and a set of tires and when i check the shopping cart it said Tire Pressure Monitoring System sensors availble for $172.00.....
First of all im guessing the Tire pressure monitoring system sensor is a device that tells the hummer when your tire pressure is low, if im not right then can someone please explain it to me
Second do i have to buy the Tire pressure monitoring system sensor or can I just buy the tire and rims and put them on my hummer and start driving
Please just give my your advice on this.........is it better to just buy the sensor or is it better to just forget about it and check to tire pressureon your own
Old Aug 6, 2007 | 10:18 PM
671H3's Avatar
Default RE: Rims and Tires
I kinda thought of that too....
Old Aug 6, 2007 | 10:45 PM
importkiller's Avatar
you do not need the sensors but you might get the service TPM message when you start the truck, if you do get the message just push in the trip odometer stalk and it will go away till your next ignition cycle. I have had no sensors for a year now and have recieved TPM message a total of three or four times...the entire system sucks and hardly ever works. Or if you want the TPM system just have them taken out of your stock rims and put into the new ones....majority of the new aftermarket rims will fit the sensors. They are attached to the air stem that you use to fill the tire....it's all one unit. Just so you kno, I have a company that can blow away tire racks prices....many here have followed my recommendation and have used them in the past. That is if you are going with an off road or a A/T tire.... I can only guess but I think they have other street tires also.
Old Aug 7, 2007 | 01:52 AM
ORIGINAL: importkiller
Thanks for the reply man yeah the whole sensor thing threw me off when i was looking into tire and rims and what company are you talking about...right now i only looked into tirerack.com. And Im looking for a good style in the rims and some street tires since Im not going to be off roading with my Hummer...I know must of you guys will be like what if your not going off road why did you buy a hummer....but im gonna mod out my Hummer so I can show it [sm=wootwoot.gif]
Caraddict
57
Mar 28, 2018 12:42 PM
mickeymouse
May 13, 2016 09:56 PM
bighead
Aug 2, 2009 08:54 PM
mickeymouse
Jan 10, 2007 05:59 AM
Sisco22
May 12, 2006 02:48 AM
