review on Rockford fosgate H2 stero upgrade
Old Aug 16, 2011 | 07:42 AM
cannoncollector's Avatar
Default review on Rockford fosgate H2 stero upgrade
I did buy this system.....found prices from about $1200 to $500....bought at $500 of coarse.....it includes 2 new front speakers and a big plastic bass sub woofer and amp that fits under back seat...it uses factory type harness to plug into factory radio.....heres the problem I found the factory radio bass control does not lower the rear bass box, so you cant listen to the radio at low level without hearing boom boom boom, way to much bass, but at high volume it sounds ok, so I put in a togle switch that shuts down the big bass box and turn it on when looking for loud volume with base...Anyone else had this experience?
Old Sep 2, 2011 | 10:19 AM
Luigi's Avatar
Hello, Cannon...
For your opinion, the Rock system works on the H2 MY2009, too...?
Old Apr 21, 2012 | 02:36 PM
dbhagat's Avatar
Default Rockford Fosgate upgrade for H2
Just ordered mine.( $ 500 from Source Motors - Custom. Accessories.) Will fit and and give the feedback. If you found a solution to the bass control issue, please let me know !
Old Apr 22, 2012 | 09:30 PM
twinmill28's Avatar
Hi dbhagat--you've jumped in on an old post. But I'll give you my 2 cents. I installed the Fosgate set-up, bought it brand new off Ebay for $250, and that's about all it's worth.
It'll give you more bass, but not enough to need to shut off the sub.
The only thing I don't like is the replacement door speakers tend to sound tinny when I'm playing CD's. I've thought about moving them to the back doors and putting in a couple of Alpine speakers up there. I'd recommend finding some replacement door speakers for the front and putting the fosgates in back door.
Good luck with it, curious to know what you think.
Old Apr 23, 2012 | 11:55 AM
dbhagat's Avatar
I was under the impression that the rear door speakers are smaller ? (5.25" vs 6.5 for front)....I will update this post once I get it installed. thanks !
Old Apr 24, 2012 | 10:10 PM
twinmill28's Avatar
Hmmm, would figure that you couldn't interchange the damn things. I've never looked into it, just figured it should work.
Old May 1, 2012 | 09:28 PM
calif phil's Avatar
I installed the Rockford System in my 06 and it works fine. I didn't replace the door speakers. I do not have a problem with too much bass. If anything it could be more. All in all I am happy with it.
Old May 2, 2012 | 04:30 AM
Luigi's Avatar
Some idea for 08 model?
Old May 2, 2012 | 05:22 AM
dbhagat's Avatar
I am getting it installed as we speak and I should be getting it back today afternoon. Will give an update after using it for a day or two.
Old May 2, 2012 | 05:35 PM
dbhagat's Avatar
Well, just got the vehicle back. I found there is too much bass for my liking, The front speakers sound much clearer than the original bose ones.
I reduced the bass in the dashboard equalizer setting to minimum but feel I still need to reduce it more,,, there is too much "boom",,,, any suggestions?>
I usually listen to smooth Jazz and so the front speakers are perfect.
grey714
Aug 26, 2010 11:57 AM
EarlsSVT
Jun 9, 2010 09:22 PM
h2sutithaca
Feb 3, 2010 10:29 AM
PhxH2
Sep 24, 2009 05:02 PM
JeepeaterH3
Mar 16, 2008 02:44 AM
