Retrofitting transfer case
Old Sep 2, 2016 | 06:34 AM
kakash's Avatar
Default Retrofitting transfer case
Hello,
Does anyone know if 5.3 L LH8 V8 engine transfer case retrofits 3.7 2007 hummer h3? This is the only single one available at polish market with a good price too, so it would make sense..
Cheers!
Old Sep 2, 2016 | 08:38 AM
rsc's Avatar
rsc
Yes, they all interchange. The only difference will be whether it is 2.6:1 or 4:1 gearing from a base or adventure/off road model.
Old Sep 2, 2016 | 01:15 PM
What he ^^^^ said X2.
Old Sep 2, 2016 | 04:05 PM
Mkawas's Avatar
To compliment, the Borg Warner 4493 is the 2.6:1 and the 4494 is the 4:1, if you need any spares in the future
Old Sep 3, 2016 | 07:51 AM
Yep, they are interchangeable. No different on the outside or inside between I5 and V8.
The high range ratios are all the same.
The low range gear ratios can be very different.
Below are some different ways to tell what you had.
NR4 - Borg Warner 4493 = 2.64:1 low range
NR6 - Borg Warner 4494 = 4.01:1 low range
Old Sep 3, 2016 | 12:44 PM
kakash's Avatar
Thanks for all the replies!!! You're helping me out big time
So if I fit the 5.3 liters t-case to my h3, I won't get a speed decrease on high range ratio, e.g. Im not looking at a less mph on highway?
Cheers
Old Sep 3, 2016 | 03:36 PM
happythree's Avatar
in normal 4 hi open its direct, 1;1 no change.
Old Sep 8, 2016 | 01:20 PM
Mkawas's Avatar
Cheers
Not in 4Hi or 4Hi lock. You will see change in gear ratios if you engage 4 Low, and the ratios depend on which Tcase you chose.
ride450
Jun 26, 2021 02:00 PM
hudson4269
Mar 7, 2017 09:12 AM
Lewis N
Feb 3, 2008 08:22 AM
mh307
Oct 16, 2007 05:24 PM
Jul 19, 2006 03:05 PM
