Retrofitting transfer case
Hello,
Does anyone know if 5.3 L LH8 V8 engine transfer case retrofits 3.7 2007 hummer h3? This is the only single one available at polish market with a good price too, so it would make sense.. Cheers! |
Yes, they all interchange. The only difference will be whether it is 2.6:1 or 4:1 gearing from a base or adventure/off road model.
What he ^^^^ said X2.
Originally Posted by rsc
(Post 338844)
Yep, they are interchangeable. No different on the outside or inside between I5 and V8.
The high range ratios are all the same. The low range gear ratios can be very different. Below are some different ways to tell what you had. NR4 - Borg Warner 4493 = 2.64:1 low range NR6 - Borg Warner 4494 = 4.01:1 low range |
Thanks for all the replies!!! You're helping me out big time
So if I fit the 5.3 liters t-case to my h3, I won't get a speed decrease on high range ratio, e.g. Im not looking at a less mph on highway? Cheers |
in normal 4 hi open its direct, 1;1 no change.
Originally Posted by kakash
(Post 338878)
