Reprogram Tire Sensors???
Old Jun 14, 2006 | 10:50 PM
OUTLAW's Avatar
Default Reprogram Tire Sensors???
Bought chrome H3 takeoffs to replace the aluminum rims on my Adventure. The sensors from the aluminum rims are going into the chrome H3 takeoffs. Asked the wife to call the dealer too see how much it would cost if I had them do the switch. Dealer reply was for $210.[sm=WTFsgign.gif] when questioned why so much, the answer was they had to reprogram the sensors??? Is this just BS or what?
I have a feeling they were taking advantage of her because she's a woman.
Old Jun 14, 2006 | 11:05 PM
Linus Gump's Avatar
Default RE: Reprogram Tire Sensors???
I thnk I would agree with you on that. Since the TPM is standard on all of the H3's, if you are taking wheels off of another one, why would you need to reprogram them to go back on the same vehicle? If it is a frequency thing, why cant you use your old ones in the new wheels?
Old Jun 15, 2006 | 01:59 AM
Sewie's Avatar
As long as you don't mix in the spare you shouldn't need to reprogram. And even if you do, the steps on how to do it are in the owner's manual. Its a PITA but you can do it yourself.
Old Jun 15, 2006 | 02:30 AM
CruisinCarAudio's Avatar
Even the spare tire has a tire sensor in it, they did that so you could use that in the mix when you rotate your tires, The steps in the manual arent necessary, i thought i had to do it when i had the tires rotated at 7500, but the hummer service manager, said it wasnt necessary because the system will reset itself after about 400 miles, i was skeptical but it did, almost right on the money, the sensor in each tire send a signal once every 60 seconds at speeds over 40mph, and once per hour at idle, hope this helps
Old Jun 15, 2006 | 09:45 AM
dilo2001gt's Avatar
that bull i did mine at a local shop it cost me $80 to switch the rims and sensors
Old Jun 16, 2006 | 01:48 AM
nascar 17's Avatar
discouint tire can do it for you .they will charge you 80 and you can have a life time rotation and balace for the price of 80 so well worth it for lief time rotate and balance.
Old Jun 16, 2006 | 05:57 PM
Sewie's Avatar
ORIGINAL: CruisinCarAudio
Yes, the spare has a sensor, but AFAIK, it is not monitored. I rotated mine in when I got a flat and the SERV TPM message came on and stayed on until I swapped them back. And I drove well over 400 miles. Are you sure the dealer rotated in your spare? Usually they won't unless you tell them to.
man-of-war
Mar 15, 2014 01:22 PM
jmoffatt
35
Nov 10, 2012 03:03 PM
skeeet
Sep 16, 2006 03:12 AM
OUTLAW
May 16, 2006 12:34 AM
TIM06H3
Feb 8, 2006 10:00 AM
