Replacing Steering Stabilizer-Need Suggestions to get old one off
Old Jul 5, 2011 | 06:55 PM
solarflare's Avatar
Default Replacing Steering Stabilizer-Need Suggestions to get old one off
Well I think the title says it all.....just did a Rancho replacement on all four shocks.....big difference over stock.....!
Went to do the steering stabilizer, because the oem one is toast (2007 H2)......got the one end off, but the other won't budge. Are there any tips or tricks to get the ball bolt out??? I've done many of stabilizers in the past and it usually only takes about 10 minutes.........this one was over an hour of trying and I finally walked away.......any suggestions are welcome!!!!
Old Jul 5, 2011 | 07:45 PM
Muddydawg75's Avatar
That actually requires a 2 jaw puller like the Kent Moore J 24319-B listed on page 2-54 of the service manual.
Old Jul 7, 2011 | 09:20 AM
solarflare's Avatar
well after giving it a good dose of weasel p**s it came off with a slight pull......
All good to go now!
Old Jul 7, 2011 | 09:31 AM
interesting... I broke mine taking it off... had I not been going to upgrade to the Fabtech Dual steering stabilizers, I would have been screwed...
Old Jul 7, 2011 | 01:01 PM
solarflare's Avatar
The only thing I don't care for with the new rancho, is that you have to use a bracket, which attaches to the arm with 2 u bolts. Seems to work fine. I just don't understand why they can't use the original hardware and hole for the new installation, instead of that bracket...???
Old Jul 7, 2011 | 02:19 PM
mgurgone's Avatar
Solarflare: I will be doing the same install this weekend of a Rancho Steering stabilizer on my 2008.
Any other advice on pulling the stock one off?
Old Jul 7, 2011 | 03:32 PM
If you change the location of the Rancho bracket you "COULD" limit your steering radius.
I did with the Fabtech to prevent rubbing... works GREAT.
Old Jul 7, 2011 | 04:02 PM
solarflare's Avatar
Be sure to spray the bolts with a lot of PB Blaster or Fluid Film, etc.....let it sit for at least 12 hours. My rig only has 26,000 miles...and basically sits in the winter. It really wasn't rusty at all.
You can use a pickle fork to remove the bolt that has a pressed fit, or any other tool like that. The puller would be ideal.
Attach the bracket to the shock. Set the new shock at 15 3/4" center to center and install the lower bolt/nut. Then install the bracket. The bracket will set the shock over and the bracket sits to one side. You will see that in the instruction sheet pic.
Tighten up all bolts/nuts, and then turn vehicle on and check for binding or anything else that might not be right.
I hope that helps!
I don't know if the 2008 model is different under there.....I know my old 08' drove a lot better than my 07'....
Old Jul 7, 2011 | 05:29 PM
Hey Solarflare, how have you been?
Old Jul 11, 2011 | 10:01 PM
Gleamor's Avatar
I broke the heck outa mine trying to take it off. Ended up having the guys at East Coast Off Road finishing the job. Thats what I get for using a BFH
tyler1bo
Jul 4, 2012 11:48 AM
palmxjjsi
May 6, 2011 11:49 AM
mgurgone
Jan 19, 2011 01:15 PM
MACDONTPLAY
Dec 30, 2010 04:06 AM
cagef15
Jun 11, 2008 03:31 PM
