Replacing front wheel hub
Old Jul 7, 2013 | 10:25 AM
06PullUouT's Avatar
Default Replacing front wheel hub
Does anyone know of a cheap place to order the wheel hub assembly? I found gmpartsdirect @ $212. That was cheapest I have been able to find. Also, when replacing the wheel hub is it pretty much the same as the H2 in regards to removal and replacement? If anyone has a writeup for the H3 could you post it up. I plan on tackling this next week.
TIA
Deryl
Old Jul 7, 2013 | 12:09 PM
gray ghost's Avatar
Wink hub assembley
try rock auto they have fast shipping and good prices.
Old Jul 7, 2013 | 04:00 PM
06PullUouT's Avatar
So I should buy the Timken SP550311? It is the one with the speed sensor.
Old Jul 7, 2013 | 04:04 PM
Calls for 1hr labor time.
remove wheel, caliper, rotor, wheel speed sensor, axle nut & washer,
hub bearing mounting bolts, remove wheel hub and backing plate. Clean & lube steering knuckle mounting contacts, and install new hub bearing assy. with backing plate, and all other parts removed.
Torque wheel hub bolts 133 ft lbs, drive shaft nut 173 ft lbs, wheel studs 103 ft lbs. GL
ebay has the best price around:
Front Right or Left New Wheel Hub Assembly 4 Wheel ABS 4WD 4x4 Passenger Driver | eBay
smileynialley
Feb 26, 2015 03:15 PM
jaymazurk
Jun 27, 2014 05:07 PM
PutJ
Jan 14, 2013 01:09 PM
ultraclassic01
Oct 4, 2012 10:25 AM
Brodie
Apr 2, 2009 11:08 AM
