Replaced my battery , ac blend issue
Old Sep 10, 2013 | 11:10 AM
thedave8's Avatar
Default Replaced my battery , ac blend issue
My battery was getting really weak so I figured I'd replace it before I got stranded . I didn't have a memory saver at the house but didn't think I needed one. I replaced battery without an issue, but now my ac only blows cold on te lowest setting , if you go one click to the warmer side it goes full heat. I understand after battery is disconnected ,the actuators will " reset" themselves when battery is reconnected. So the only thing I can figure is my actuator is bad in that it won't re synchronize ? If I had memory saver I mighta avoided all this .......
Any input greatly appreciated
Old Sep 10, 2013 | 09:22 PM
Reineke's Avatar
You can try the relearn, where you turn the temp dial all the way to the right, the fan speed all the way to the right and the last know all the way to the left and press and hold the outer buttons until they start flashing. Don't adjust anything until they stop blinking. That may work for you, but some have found that if you add a resistor in series to a wire on the back of the control unit, you will no longer have the issue. I'll see if I can dig up the instructions...
Old Sep 10, 2013 | 09:27 PM
Reineke's Avatar
Old Sep 11, 2013 | 04:55 AM
thedave8's Avatar
I will give that a shot
Old Sep 11, 2013 | 06:13 AM
thedave8's Avatar
Tried the reset...... Still goes full heat if you go 1 to 2 clicks off full cold....
madmayo
Jul 18, 2015 04:17 PM
citiboy
Jul 7, 2014 09:22 AM
conifers4
Feb 19, 2013 11:43 AM
Lionel
Feb 24, 2009 08:43 AM
hotrod
Oct 20, 2008 02:37 AM
