Replace h3 sunroof gasket
Old Jun 1, 2013 | 08:46 PM
loud pipes's Avatar
Default Replace h3 sunroof gasket
Has anyone removed the sunroof to replace the gasket? It is a simple as it looks where it's just removing 4 bolts? Thanks.
Old Jun 2, 2013 | 06:08 AM
Broken Halo's Avatar
I don't know why you're replacing the seal, but keep in mind their design intent is to keep out debris, reduce water intrusion and cut wind noise, not be water tight. That's why there are drain tubes.
Old Jun 2, 2013 | 08:37 AM
loud pipes's Avatar
Replacing the seal because mine has a small tear in it, letting water come in thru the dome light under heavy rain and the drain tubes can't handle the load.
Old Jun 12, 2013 | 06:41 PM
nelly27281's Avatar
Would you mind if I ask from where you got it and how to change it...? as mine also got few tears on it.
Thanks.
Old Jun 13, 2013 | 01:58 PM
loud pipes's Avatar
Nelly, as painful as it was, I got it from the dealership. I haven't changed it yet, so no real advice on the best way to go. 4 screws hold the glass frame to the track rails, so I am going to remove those and put the gasket on the glass while it is off the vehicle.
Good luck!
Old Nov 5, 2015 | 03:33 PM
nelly27281's Avatar
I know it's after looooong time, but were you be able to crack it down? I am planning to do it this weekend, so thought of getting some more tips.
Old Nov 5, 2015 | 06:26 PM
happythree's Avatar
the service manual is fussy about the spacing of the panel so be careful getting it back in place.
it says front,.020 below the roof metal, the back, .020 above!
must be for air/water flow??
how does the rubber attach?
psych0
May 26, 2010 06:31 PM
majhero
Feb 2, 2009 10:33 AM
silverwarrior
Nov 11, 2007 05:31 PM
H34 pleasure
44
May 4, 2007 04:17 AM
