Removing the PCM
Old Sep 28, 2006 | 10:58 AM
HummerGuy's Avatar
Default Removing the PCM
I'm assuming this very easy from looking at it. There aren't any secrets I'll find out when I start doing it are there? I'm assuming I should disconnect the battery beforehand.
Old Sep 28, 2006 | 11:25 PM
lotus4s's Avatar
Default RE: Removing the PCM
ORIGINAL: HummerGuy
Yes, disconnect the battery. Removal instructions will come from PCMforless. Pull up the red locking tab, lift the hinged gray locking tab on the front and pull the plug straight out from the socket. It's a little easier to get your hands in there to reach the plugs if you remove the pcm from it's mounting bracket first by releasing the snap in tab on each side. Pretty simple and only takes a couple of minutes.
Old Sep 29, 2006 | 02:27 AM
Dennis's Avatar
ORIGINAL: HummerGuy
LMAO..You and me man[sm=icon_cheers.gif]
Check out this old thread..PCM
BlackTiger
Oct 23, 2006 11:55 AM
rmp0012002
Oct 6, 2006 10:28 PM
Tina514
Jul 13, 2006 02:53 PM
blackstangs281
May 9, 2006 03:42 PM
CruisinCarAudio
Dec 7, 2005 03:06 AM
