Remove front turn signal plastic cover
Old Apr 25, 2010 | 09:26 AM
vernrose's Avatar
Default Remove front turn signal plastic cover
Need to replace front turn signal bulb. took off front bumper, but I am having difficutlty getting the yellow plastic cover off the front to access the bulb. It has fout plastic clips on each sides as part of the cover, but when I lift these the plastic cover will not release. I've tried to gently, with increasing force, to pry the covers off but it is going to take a lot of force which may break it. I guess this is the General's way of keeping Mr. Goodwrench employed. Any suggestions?
Old Apr 25, 2010 | 12:01 PM
RKSmith163's Avatar
I think the bulb is a twist lock accessed from the back by removing the inner fender liner. I am not sure. I did all LED's a couple of years ago so I don't exacty remember. Do a search on this forum and you should find the answer for sure.
Old Jun 4, 2010 | 05:31 PM
h3xxx's Avatar
Have to access it from the wheel well. All it is is about 4-5 plastic rivets and a 4-5 10mm bolts and its off. Should be self explanatory from there, but its been awhile so I could be wrong.
Old Jun 4, 2010 | 05:44 PM
2wheelmonster's Avatar
I believe it's a twist and pull out bulb from the behind it
DanRay83
21
Dec 2, 2014 02:57 PM
groomsxxx
Apr 11, 2013 07:19 PM
vernrose
Apr 25, 2010 07:54 AM
Agente
Jul 6, 2009 11:05 PM
hotrod
Feb 17, 2009 04:40 PM
