remote starter problems
Old Nov 19, 2008 | 02:25 AM
winnipeghummer's Avatar
Default remote starter problems
Hey there everyone i just got my first hummer . its a 2006 yellow h2 and i was hooking up a remote starter / alarm but the only thing left is to hook up the bypass to to passlock module . but the only problem is i cant find the darn thing can anyone help me with this.
Old Nov 19, 2008 | 06:20 AM
BMJM100's Avatar
Default RE: remote starter problems
Your pass lock wires are usually located in the steering column wiring going towards ignition. 3 thin wires, yellow, black &black w/yellow stripe.
Door locks may require up to 4 relays.
Old Nov 19, 2008 | 11:07 PM
thanks ill look for them
Old Nov 20, 2008 | 05:29 PM
bflorin's Avatar
There is a module that connects directly to the data bus so you dont have it rigged w/ a key stuck under the dash... Door locks shouldn't require any relays, just tap the unlock from one of the rear doors. If i remember correctly there was an issue w/ tapping the drivers door think it only unlocked itself, not all doors.
Old Nov 21, 2008 | 12:13 AM
Can't help you as MURRAY'S installed mine but HEY AND WELCOME Fellow Pegger!!!!
Old Nov 21, 2008 | 02:23 AM
cool another pegger
Old Nov 24, 2008 | 01:44 AM
is there another way of telling which wires are for the passlock bypass
Old Nov 24, 2008 | 11:54 AM
bflorin's Avatar
Instructions for the module I used-
http://ifar.ca/en/download/177/insta...l.rev-4.9j.pdf
Old Nov 24, 2008 | 12:48 PM
HumminNBoatin's Avatar
I used to install these for circuit city back in high school. I would honestly recommend not to use the Remote Start feature. They almost cause problems several years down the road. Then it gets expensive to make repairs etc.... I was a MECPInstaller and that is my professional opinion.
Old Nov 30, 2008 | 02:20 PM
hummerfamily's Avatar
I agree that the remote feature will cause problems in the long run
