Rear wheel hub/assembly?
Old Oct 14, 2015 | 07:13 PM
Synthetickiller's Avatar
Default Rear wheel lug stud/bolt?
What is the model of lug bolt/stud for rear hub?
One was stripped out today & I have to replace it.
Also, is this a fairly straight forward install? It seems to be easy, but you never know.
Edit:
Ended up ordering part GM Genuine 09595178.
Should fix everything.
Mods can delete.
Old Oct 14, 2015 | 10:39 PM
happythree's Avatar
i saw a few videos on u tube and they all used a hammer to knock out the stud.
i dont like ever using a hammer,,,,but??
after that take a good nut with you to check the new stud.
auto zone?, parts store?, dealer will cost a lot but cant be much.
you put it in and pull it into place with a nut and maybe some spacer washers to draw it in.
note,,,ive never done it!!
Old Oct 14, 2015 | 10:59 PM
A lot of places didn't stock it, after googling around a bit.
I ended up just ordering one off of ebay for $6 shipped. I can't complain about the price.
I also probably saw many of the same videos. Hopefully, it'll be fairly straight forward.
Old Oct 14, 2015 | 11:28 PM
happythree's Avatar
report back ok? im curious how much space is needed behind the flange to get the new one in.
Old Oct 16, 2015 | 09:42 PM
Happy Hummer's Avatar
A good trick is to pound it loose just slightly then use a saw or grinder a cut it down super small. Then take a punch to pop it out.
Old Oct 16, 2015 | 10:15 PM
That's a very good idea. I have a cutter that'll make quick work of it. I can just tap it out with a 4 lb hammer.
Getting it in will be another thing. I've seen mods where the dust/mud cover is cut & you rotate the assembly, & insert a modified wheel stud. A grinder is used to cut off part of the head (maybe 20# to 30%) and then is tapped into the hole with an air hammer. Not sure if I'll go that route or just take everything apart.
Old Oct 19, 2015 | 07:00 PM
skeeter's Avatar
I just used a hammer to knock it out, and then just fished it in by hand, and then I used a nut and a spacer to seat the stud in. extremely easy, and not cutting required
Old Nov 14, 2015 | 09:42 AM
As much as everyone hates this, I ended up taking it to someone.
I had 20+ stitches sewn in a day or 2 before I could get to it & I was told any strenuous work could tear open 2 incisions I had.
The work took about 1 hour to do, so I'd imagine it'd take 2+ with my current set up.
BUGMAN
Jan 29, 2019 07:54 PM
jsbihn
Dec 5, 2014 01:10 PM
parrip
Jun 29, 2014 07:36 PM
CharlieDeltaJuliet
Sep 5, 2013 04:12 PM
ultraclassic01
Oct 4, 2012 10:25 AM
