rear tire carrier
Old Dec 12, 2005 | 11:57 AM
beezer12's Avatar
Default rear tire carrier
where can i get one so i can utilize all the space in the rear of the vehicle. if you have one and really like it would you please recommend it to me and send a link to their website. thanks.
Old Dec 15, 2005 | 07:25 PM
shortbus's Avatar
Default RE: rear tire carrier
did you check your local dealer? the new ones on the '06 are nicer than the earlier ones. i don't know who makes an aftermarket model.
Old Dec 15, 2005 | 09:05 PM
Intercooled's Avatar
ORIGINAL: shortbus
Is the 06 any different from the 05?
Old Dec 15, 2005 | 09:10 PM
Let me give you my take on the rear carrier. The GM one is very nice, very heavy duty and works well. For me, it is a pain to use. It swings open, so you cant be backed up against another car, bushes, wall etc. If you want to open the rear. If space in the interior is real concern than maybe the rear carrier is the way to go. I just find that swinging that thing open to put in some grocery bags or a box from Home Depot to be a pain. If your parked so another car is behind you, you will have move the truck up so you can have clearance to swing open the carrier and then lift the rear hatch. I also personaly think the H2 looks better with out it. The Gobbi roof rack with tire carrier is nice and will give you peice of mind knowng you have the spare with you.
Just my 2 cents!
Old Dec 15, 2005 | 09:49 PM
shortbus's Avatar
i agree with the space constraint, but i'm not into lifting an 80lb tire off the roof rack in the rain. i don't know if the '05 is different than the '06, i know it's different than mine, it's got a beefier catch, not just a pin to hold it in place. i just got a gobi, but without the tire carrier, that way i won't be tempted to try to stow it there. besides, i like not being able to see out the back window, the 37" toyos do a better job of blocking the view than the stock tires.[]
Old Dec 16, 2005 | 01:09 AM
efrainl956's Avatar
When I need space, I just take out my spare tire and leave it in the garage. I do carry, however, a portable air compressor and a tire repair kit. I also cross my fingers just in case I think that if an H2's stock tires are hardy enough to withstand rough terrain, they should be hardy enough to withstand a trip to Walmart. I even travel out of town without it !
Old Dec 16, 2005 | 02:33 PM
shortbus's Avatar
there's not much on the road these days that will give you a flat. our last trip to the desert, we had one guy pick up a construction staple in a stock tire, but it held long enough to get back to town and replace it. having the built in compressor helped.
Old Dec 16, 2005 | 05:02 PM
efrainl956's Avatar
By the way, that spare tire might weigh 80 lbs, but it seems like a 100. I don't think my wife would be able to change the tire if the need arose.[:@]
Old Dec 16, 2005 | 07:56 PM
shortbus's Avatar
your wife has the advantage of just calling triple A to have someone do it for her. i wouldn't feel right having someone else change a tire for me.
Old Jan 6, 2006 | 07:52 PM
Last_LS1's Avatar
hello! While I don't own an H2, I know of an awesome aftermarket tire carrier by predator motorsports. It also has a drop down feature, which is awesome!! Just swing it out, pull the pin out and drop it down. You could go to predatormotorsports.com or check around other web sites for one cheaper. I know stallioncustoms.com has one, I go there for my H3 parts
Andreas_Sweden
Mar 19, 2025 12:16 PM
danaw
Jun 4, 2022 01:17 AM
wikidh2
Jun 12, 2007 01:42 PM
Calgary
Mar 27, 2007 01:05 AM
Intercooled
Sep 26, 2005 01:31 PM
