Rear end looks lower?
Old Jan 12, 2009 | 09:01 AM
RICHINTX's Avatar
Default Rear end looks lower?
I have a 03 H2 and went out today and the back end looks lower than usual. Looks like I have 2000 lbs in the back end which make the front higher.I know it has the air bags on it so could both of them gone out at the same time because it is even on both sides. It still rides the same, just looks weird.
Old Jan 12, 2009 | 03:25 PM
calif phil's Avatar
Default RE: Rear end looks lower?
Does the compressor come on and pump it back up level when you turn the key on?
Old Jan 12, 2009 | 07:55 PM
brrmo777's Avatar
Sounds like your compressor is not working.
Old Jan 13, 2009 | 06:27 AM
hummerfamily's Avatar
I think you Hummer just a case of the Dag *** and wants a day or two off. but then again its prob. the air ride going flat.
Old Jan 13, 2009 | 08:20 AM
I have seen some of the air suspension system develop leaks also,
Old Jan 15, 2009 | 03:25 PM
HumminNBoatin's Avatar
On Really cold days my truck gets a case of droppy *** too. Usually goes back to normal once its running.
Old Jan 15, 2009 | 04:02 PM
rmoore's Avatar
My H2 is doing the same thing. Started about 2 months ago and is getting progressively worse, on an uphill incline it'll go down in a couple of hours. I have a date with the dealer Tuesday after MLK to replace the airbags. I'll let you know details.
Old Jan 21, 2009 | 12:37 PM
RICHINTX's Avatar
I took it in and they said my air shocks were leaking. Had them repaced for $800. I had to have the rear latch handle replaced also $500. They have to replace the whole assembly not just the handle.
Old Jan 21, 2009 | 02:03 PM
$800 just for BAGS ALONE??? Dude you got taken if that was the case. It takes literally 15 minutes to change a bag. And they cost like $125/Each
Old Mar 2, 2009 | 01:29 PM
Thunder Cat's Avatar
anyone else had them changed? How much did it cost you? mines starting to sag overnight
