Rear Door Power Lock Issues
Old Jan 28, 2017 | 11:52 AM
jsbihn's Avatar
Default Rear Door Power Lock Issues
Hey all,
I have been having some issues with my rear door locks
Both doors, not the rear hatch.
I will lock or unlock the doors, but the locks in the back dont seem to work properly.
Either they will unlock, lock, or they will sorta lock/unlock (meaning that the lock moves but not enough to lock or unlock the door
Does anyone have any ideas.
Just seems weird that both the rear doors have this happen in the same way.
Any help is appreciated
Old Jan 29, 2017 | 10:49 PM
flyday58's Avatar
My wife's 08 had this issue but with all four locks. They also made a noise like the gears were stripping, a sort of buzz when you hit the unlock buttons, fob or interior. One, two, or three of them would screw up at the same time and seemed worse when it was hot out. I replaced all four and had no problems with them since. They're just cheap Hecho en Mexico units and I think the motors cause the gears inside to strip.
Old Nov 2, 2018 | 09:26 AM
adhoutx's Avatar
Originally Posted by jsbihn
Hey all,
I had the same problem ,changed driver and rear driver door lock actuator no change and I was about to change the liftgate actuator . I checked the fuse box by driver door and found a 20 amp fuse says LOCKS changed that and everything is good now.
Old Jun 2, 2019 | 01:58 PM
hummer_on_fumes's Avatar
Hey all,
I'm having this EXACT SAME ISSUE. Did you ever figure it out? I tried replacing the "LOCKS" fuse but it didn't make a difference.
euro55
Mar 6, 2017 07:29 PM
Wfive
Feb 19, 2015 03:52 PM
aaronpriest
Jun 17, 2012 08:49 PM
urockradio
Feb 1, 2010 08:22 PM
hilljob26
Sep 9, 2007 09:00 PM
