rear door auto lock issue
Old Sep 29, 2014 | 04:27 AM
jsbihn's Avatar
Default rear door auto lock issue
Ok, so I have an issue with my rear drivers side door exterior handle. It has been this way since I purchased the car. The handle seems to not close all the way... almost like it is binding, but I can then push the handle completely in with no problem.
Now that wouldnt be a big deal except if I dont push it all the way in and it is left out, it seems to not lock. Yes it is latched but when the grab handle is left out the 1/2 inch or what it may be when I close it without puching it in... the lock on that door wont work. If I push the handle in, everything is fine and it locks.
Other then the exterior handle sticking out a 1/2 inch, then if I push it in and then it will allow the door to lock... everything else about the door and the operation of it seems normal.
Any ideas?
Old Sep 29, 2014 | 04:36 AM
Shayne100's Avatar
Sounds like a mechanical fault rather than anything else , remove the panel surrounding your inner door handle and inside there's two 10mm bolts . Remove them and you can pull the interior door dressing off its only held with plastic pop plugs . Then take a look at the mechanism , its possible something is jamming in there or maybe you need to replace a spring . If you do decide its a weak spring take the spring off and heat it until it glows red then drop it in cold water , that might be enough to return it to its original strength and will save you searching for a replacement .
Old Sep 29, 2014 | 08:47 AM
calif phil's Avatar
I would try and lube it up real good with WD40 or similar first.
chuffysplace
Aug 10, 2015 03:42 PM
ChristianAnarchist
Aug 31, 2014 09:18 PM
ChristianAnarchist
Dec 5, 2013 05:26 PM
bluedoggy
Aug 26, 2009 03:05 AM
