rear doesn't open
Old Jul 7, 2010 | 03:35 AM
big toy driver's Avatar
Default rear doesn't open
I can hear the servo working but the handle will not open the rear hatch how do i get the door open so that ican work on this problem. this is an 06 H2.
Old Jul 7, 2010 | 08:00 PM
bosch's Avatar
Default some help
i looked at the service manual and you would have to make sure the lock is trying to work ,, if it does i am ruling out an electrcal problem .
first try unlocking the rear hatch wial pulling and or pushing door in to see if the lock is jamed . if the door still will not open , the only way i saw on the parts brake down was from the inside to remove the inner pannel . if you can get to the bolts .from what i saw , the bottom tie downs at the bottom of the hatch have to be removed it also showed clips or bolts at the top ... good luck ...mike
Old Jul 9, 2010 | 07:15 PM
Thanks for the reply mike it started working again so i'm thinking the seliniod is going bad or isn't working when it get hot here in AZ. i guess i will be down to the dealership for a new one soon.
pauly1052
Jun 27, 2015 04:51 PM
LS12FAST4U
Oct 6, 2014 01:07 PM
johnmully
Sep 14, 2013 11:51 AM
dmurdock
18
Feb 23, 2009 04:06 PM
Dennis
Apr 3, 2007 10:54 AM
